Go Back   JDMCITY.COM > Technical Forum > Naturally Aspirated
Old 08/08/2012, 04:39 PM   #1
turboteggy
turboteggy's Avatar
turboteggy is offline
Default Ls intake vs gsr intake
looking for opinions here. I have a gsr with gsr intake. I feel like the ls intake would flow alot better. What do.you guys think?
when the turbo spins the bullshit ends.
VTEC all day!!! well till you run out of oil.
Old 08/08/2012, 06:27 PM   #2
H22CB9
H22CB9's Avatar
H22CB9 is offline
Default Re: Ls intake vs gsr intake
As far as I know the ls intake will not bolt on a vtec head
Old 08/08/2012, 11:43 PM   #3
P98
P98's Avatar
P98 is offline
No it wont
LT1 T/A
Old 08/09/2012, 12:04 AM   #4
A modified GSR plenum went 9's in an all motor car way back when. They work.
Old 08/09/2012, 09:37 AM   #5
Dj Technick
Dj Technick's Avatar
Dj Technick is offline
I don't know why you would want to replace the stock snail with anything unless it's a badass aftermarket one. The stock GSR intakes work great.
Damn that's a good lookin' pixel car ;)
Old 08/10/2012, 07:24 AM   #6
crxh22honda
crxh22honda's Avatar
crxh22honda is offline
blox? its not badass but dont they do a bit better?
Old 08/10/2012, 08:43 AM   #7
Dj Technick
You'll lose midrange. The stock GSR intake manifold provides a lot better mid range power than a blox one will. You might gain a little more top end switching to a blox but nothing that'll make it worth the change.
Old 08/23/2012, 09:35 PM   #8
95_coupe
JDM Fan
95_coupe is offline
Ls intakes do not fit gsr heads and if you want one that flows good a itr manifold works best
Old 08/25/2012, 01:44 AM   #9
Charlie Moua
Charlie Moua's Avatar
Charlie Moua is offline
yes sir....
I would definity give that a try.
We done it to h22 and picked up +12whp on simple h22 setups but I might be able to get the guys at map to modify a gsr one for me...
we'll see...
CNC Werx
team4piston
Jordan Tuned
Rocket Motorsports
Modern Automotive Performance
Old 08/25/2012, 04:53 PM   #10
Dj Technick
I didn't think the itr worked? Aren't they the same pattern as the b16?
Old 08/28/2012, 12:47 AM   #11
Charlie Moua
nope , gsr is different than b16/itr bolt pattern
CNC Werx
team4piston
Jordan Tuned
Rocket Motorsports
Old 08/28/2012, 08:06 AM   #12
Dj Technick
I was saying isn't the the ITR the same as the B16 and it wouldn't work on a GSR. I probably should have worded what I said a little better.
Old 09/10/2012, 06:03 PM   #13
turboteggy
turboteggy's Avatar
why wouldnt it work on the gsr
Old 09/10/2012, 07:20 PM   #14
one_slow_ej
one_slow_ej's Avatar
one_slow_ej is offline
different bolt pattern the only oem honda intake mani that will fit is the stock gsr one...
used parts, general maintenance, swaps, dyno tunes.
95 civic dx.. 6.9@104mph 1/8 mile
Old 09/10/2012, 10:45 PM   #15
turboteggy
turboteggy's Avatar
thats what i was looking for thanks
Old 11/23/2017, 08:22 AM   #16
Desy188
Desy188 is offline
Hi, I happened to see the topic. This is what I was looking for
bitpim alternative
