Go Back   JDMCITY.COM > Technical Forum > Audio/Security/Video
Old 05/28/2010, 10:30 PM   #1
Type_Riki
Hi, Im a Ricer..
Type_Riki's Avatar
Type_Riki is offline
Default help with amp not turning on
well trying to find out why my amp aint turning on to power my sub??? it aint the amp cause i tried my friends whos does work cause it was on his car and well im thinking its the wires now maybe but not sure which one...i tested the blue reme wire that goes from the amp to the stereo with a test light and it lit up so now im puzzled lol help
(__/)
(")_(")
Old 05/29/2010, 07:57 AM   #2
eg_si
eg_si is offline
Default Re: help with amp not turning on
bring that toy over
Old 05/29/2010, 08:11 AM   #3
Type_Riki
Hi, Im a Ricer..
Type_Riki's Avatar
jaja ah damn kevin knew you wouldv'e said something lol ill come over in the week
(__/)
(")_(")
Old 05/29/2010, 11:34 AM   #4
importsusa
Vinyl Specialist
importsusa's Avatar
importsusa is offline
not a huge audio guy on this but soun ds like a blown fuse, amp could of burnt out or the most common a bad ground....check grounds first and make sure it is metal to metal contact with no paint in between them.
Otherwise get a hold of Ryan (jdmb18hatch)........the master mind behind audio setups.
come check us out..............
Old 05/29/2010, 07:28 PM   #5
Type_Riki
Hi, Im a Ricer..
Type_Riki's Avatar
thanks rodnie will do if eg si cant handle it lol
(__/)
(")_(")
Old 05/30/2010, 01:06 AM   #6
jdmb18hatch
Retired
jdmb18hatch's Avatar
jdmb18hatch is offline
1. check fuse under hood on your power wire
2. check ground.
use your test light on the +12v wire on the amp, see if it lights up. audio is pretty simple to diagnose... if you cant figure it out lemme know.
Ryan
Originally Posted by H22APWRD94 View Post
a friend of a friend who was banging dudes sister, but dudes sister was really a tranny.
Originally Posted by importsusa View Post
Ha ha.....I'll run out butt naked with butter rubbed all over while I yell rape.....LOL.
Old 05/30/2010, 01:26 AM   #7
Type_Riki
Hi, Im a Ricer..
Type_Riki's Avatar
thanks man will i did test the 12v wire to my amp and it didnt turn on but i dont get it cause my fuse is still ok?? could it be the wire got messed up like smushed somewhere
(__/)
(")_(")
Old 05/31/2010, 12:18 AM   #8
Bun
Bun's Avatar
Bun is offline
i have had a powerwire get smashed and it stoped working. i replaced it it worked. also make sure all your wires arnt tucked all on the same side of your car that can do some odd things too.
B18C1
Sol
Old 05/31/2010, 04:45 AM   #9
DSM4LIFE
DSM4LIFE's Avatar
DSM4LIFE is offline
your amp should have a light on it, green is where you want it to be, if its red then it has power, if its red, check your ground and your remote wire, make sure its coming off of the soild blue wire from the cd player harness, if no light at all then you have a power problem and check the big fuse and connections
Old 05/31/2010, 10:28 AM   #10
Type_Riki
Hi, Im a Ricer..
Type_Riki's Avatar
fatboyben thats what i was thinking it is too my power wire must be pinched somewhere....and yea i got my wires running in opposite directions
(__/)
(")_(")
Old 05/31/2010, 10:47 AM   #11
jdmb18hatch
Retired
Running all the wires on one side of the vehicle doesnt matter. the only thing it will affect is if you do that on a high frequency setup (4 channel amp) you will get feedback and engine/ground noise.
actually, its the blue/white on the back of the radio. solid blue is the power antenna lead.
Old 05/31/2010, 01:37 PM   #12
DSM4LIFE
DSM4LIFE's Avatar
DSM4LIFE is offline
cause every time i run it off the blue with white it never works, i would try the solid blue and see what happens, thats just me from my experence
Old 05/31/2010, 01:41 PM   #13
jdmb18hatch
Retired
hes already tested that wire.
Old 05/31/2010, 01:46 PM   #14
DSM4LIFE
DSM4LIFE's Avatar
DSM4LIFE is offline
well have him switch it to the soild blue one and see what happens, if that doesnt work then its a ground
Old 08/26/2011, 03:42 PM   #15
Avaitors
Avaitors's Avatar
Avaitors is offline
if your not getting any power at all to the amp it is prolly the ground i had the problem that dirt would get in between the ground connection. i would take your ground off and clean with a wire brush and wash it let it dry and take a can if air to it than see whats going on....also check the connection to the battery itself
Old 08/26/2011, 08:03 PM   #16
P98
P98's Avatar
P98 is offline
Read the dates
LT1 T/A
