Go Back   JDMCITY.COM > Technical Forum > Naturally Aspirated
Old 02/03/2009, 04:57 PM   #1
RyAN
RyAN's Avatar
RyAN is offline
Default Idle at 200!?, help
so i've been drivin the car for about 2 weeks now(brett's ls/vtec) and when i start it it will surge at about 1500 which is not that big of a deal stops when it warms up. but just a lil bit ago i went to start it and it would crank but not turn over unless i tapped the gas like it was carbureted, then once it started it wouldn't stay started unless i held the idle at about 1000 then when i let go of gas it would drop down to about 200 and alomst die. eventually it stayed started but it still drops down and almost dies and idles at around200-300. could this be cause its dying for a tune, and hates cold weather, or what are some possible causes.
and to brett if you chime in, i left those injectors in that you had in, i still have the ones you gave me seperate could this be part of this?
also the ECU is a chipped p06
Pure Aesthetics
Cure for the lead foot
Old 02/03/2009, 06:08 PM   #2
Skorpijon
Skorpijon's Avatar
Skorpijon is offline
Default Re: Idle at 200!
if the spark plugs arent gapped propperly it will idle really low...
(my si did that after i forgot to gap the spark plugs)
idk if thats whats wrong with urs but thought id throw that in there..
Current:
2004 Corvette Z06
2002 RSX Type S
Old 02/03/2009, 07:17 PM   #3
RyAN
RyAN's Avatar
RyAN is offline
hm, i'll have to check that, i beleive it is supposed to be at .044 on this motor.
Pure Aesthetics
Old 02/04/2009, 06:22 AM   #4
LowNsloEJ6
1SickUA7
LowNsloEJ6's Avatar
LowNsloEJ6 is offline
that sounds like its getting a weak spark. my car did that until i changed dizzy cap wires and plugs. my friends truck does the same thing too. what fuel are you runnin in the car(octane rating)
08 TL-S
97 EJ6 D16Z6
98 EJ6 4Dr D16Y7 project 300,000
Old 02/04/2009, 11:57 AM   #5
RyAN
RyAN's Avatar
RyAN is offline
91, i think it may have something to do with spark plugs or timing
Pure Aesthetics
Old 02/04/2009, 12:55 PM   #6
68cam
68cam's Avatar
68cam is offline
damn dude that sucks
i dont have any info but that sucks sorry man
"The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so damn temperamental."
Old 02/04/2009, 03:40 PM   #7
RyAN
RyAN's Avatar
RyAN is offline
so far, it starts up and stays started it still idls low at first when its cold but when warms up it'll idle regular, havent let it sit for awhile and tried yet but hopefully all goes well.
joe advanced timing about 5degrees and adjusted idle screw, im hopin most of this is maily about the tune
Pure Aesthetics
Old 03/07/2009, 11:54 PM   #8
*james*
*james* is offline
It needs tuned. Mine car has been actin weird too and it was really slow for a while but I had it tuned and it has helped. Check the cam and crank timing too.
Old 03/08/2009, 01:23 PM   #9
RyAN
RyAN's Avatar
RyAN is offline
yup it needs tuned, this weather needs to hurry up, but fixed most of it, ignition timing was adjusted along with idle screw and cleaned IACV
Pure Aesthetics
Old 03/16/2009, 01:26 PM   #10
prelude97
prelude97's Avatar
prelude97 is offline
my car idles low because i have no o2 sensor do you???
Old 04/25/2009, 05:01 PM   #11
RyAN
RyAN's Avatar
RyAN is offline
now my car idles high i swapped TBs for a 68mm but the gasket to got didn't seal it so it leaked, and ran very rich and idled at a lil over 2k sounds cool though, so i put stock back on and found this now the car idles at about 1400-1500 is this the reason. BTW anyone got some sort of IM for sale
Pure Aesthetics
Old 04/26/2009, 02:44 AM   #12
Bill
Closing Threads
Bill's Avatar
Bill is offline
i dont get it is the im cracked?
Nothing is true......Everything is permitted
Old 04/26/2009, 01:00 PM   #13
RyAN
RyAN's Avatar
RyAN is offline
ya on the bottom right side of the hole there is a chip, kinda big too
Pure Aesthetics
Old 04/26/2009, 02:26 PM   #14
Bill
Closing Threads
Bill's Avatar
Bill is offline
o shit i see it
