Old 02/02/2010, 09:48 AM   #26
Em1LuiSiR
AWFD
Em1LuiSiR's Avatar
Em1LuiSiR is offline
Default Re: Have a intresting problem, with picture.
Originally Posted by remix Rick View Post
IGHT THANKS ILL LOOK IT UP
Hey let me know what u find my b16a is the same and it makes a little ticking noise to.
Old 02/02/2010, 02:01 PM   #27
nate2k5
Human Bean
nate2k5's Avatar
nate2k5 is offline
adjust valve lash, whats going on with ricky's motor is not typical
1999 Ford Expedition
1989 Volvo 245
1977 Volvo 244
1978 Cobalt 19' BR
Old 02/02/2010, 02:10 PM   #28
jordan_xX
jordan_xX's Avatar
jordan_xX is offline
If you did blow the head gasket, i suggest draining the oil asap. I'm pretty sure the antifreeze will eat the rod bearings if it sits in there too long. You know what happens after that.
'97 Type R
(Type Replica)
-Spoon Engine
-T-66 turbo
-Motec Exhaust
-Skunk 2 pistons
Old 02/02/2010, 02:18 PM   #29
Yeah, he will need to see what Is going on before auto x season....really wish I could of helped him but once he figures all this stuff out, I'll see what I can do for him....I don't like seeing peoples daily drivers out of commission.
Old 02/02/2010, 04:34 PM   #30
remix Rick
remix Rick's Avatar
remix Rick is offline
hopeing to pick up supa daves truck soon then its time to crack into the civic, like i said there is not anti freez mixed it with the oil in the pan, it was just on the top of the valve cover, not mixed in with any oil in the head ether
94 Dodge dakota
96 Civic ls Swapped
Previously owned
84 cilica supra
94 4 door civic
89 bmw
89 crx si
91 crx si
Old 02/02/2010, 04:53 PM   #31
remix Rick
remix Rick's Avatar
Thanks to 68 cam i found this, what do you think? Its called lost motion assembly and i guess honda fucked up big time the first time they put them in the b16..
http://honda-tech.com/showthread.php...&highlight=lma
94 Dodge dakota
96 Civic ls Swapped
Previously owned
84 cilica supra
94 4 door civic
89 bmw
89 crx si
91 crx si
Old 02/02/2010, 07:11 PM   #32
nate2k5
Human Bean
nate2k5's Avatar
nate2k5 is offline
i told you about the LMAs when you thought it was your "lifters". they didn't fuck up big time, for the most part they last for a long time in most heads. it doesn't prove there is something wrong with yours.
1989 Volvo 245
1977 Volvo 244
1978 Cobalt 19' BR
Old 02/02/2010, 10:03 PM   #33
garyLT1
garyLT1's Avatar
garyLT1 is offline
we better jump on this at central man not like we do anything eles in there
Old 02/04/2010, 09:09 AM   #34
IT'S THE HEAD GASKET!!!!!!!!!
Head gaskets can leak in any number of ways, just because there's no "cream" in the oil pan does not mean the head gasket is not leaking.
The fuel smell is most likely from the car running rich and lack of oil change or worn out rings.
Old 02/04/2010, 11:05 AM   #35
Valve adjustment.
Old 02/04/2010, 01:44 PM   #36
LOL....yeah kelly, we already addressed that Issue. I told him to have you guys do a leak down test to see where it is from....no word on It yet, specially since you are yelling head gasket....LOL ha ha
Old 02/04/2010, 04:04 PM   #37
Ok, also keep in mind that this engine is how old? 19-21 years old with a stock head gasket? The fuel smell/running rich could be several problems due to the age of the engine.
Like piston rings are shot or are full of carbon or valve seats and seals are bad.
Has anything been done to the engine since you had it tuned? If parts have been changed, depending on which parts, this could change the tune and cause a rich condition. The car was tuned at WOT with an A/F of 13 to 1 and part throttle was 14.2 to 14.8.
I change my oil on my eclipse every 1500 miles.....MAXIMUM!
Old 02/04/2010, 07:16 PM   #38
remix Rick
remix Rick's Avatar
just changed my oil about a week ago full synthetic, also its always ran rich after the tune any ways, and kelly how much for a leak test, im about to pull the motor here and a few weeks any ways... but how much kelly?
94 Dodge dakota
96 Civic ls Swapped
Previously owned
84 cilica supra
94 4 door civic
89 bmw
89 crx si
91 crx si
Old 02/05/2010, 08:19 PM   #39
93vtac
93vtac's Avatar
93vtac is offline
Don't rebuild the TORQUE LESS WOUNDER buy an ls or a b20 bottom end.
93 egg lsv tuned on e85 189hp WAITING ON NEW SWAP
04 GTP ? SOLD
97 geo 1,000,000hp with 100 shot. JUNKED
91 CRX si DD
08 Mercedes RIDES DUMPED
Old 02/05/2010, 08:26 PM   #40
nate2k5
Human Bean
nate2k5's Avatar
nate2k5 is offline
i am still wondering why you needed a tune, especially if its not a good one and is running rich...
its a stock motor, use a stock map...
1989 Volvo 245
1977 Volvo 244
1978 Cobalt 19' BR
Old 02/05/2010, 10:32 PM   #41
remix Rick
remix Rick's Avatar
Map? but when i bought the set up it had a p28 ecu, and it had a d16 chip in it so we had to re tune on a new chip to its on stock tune. you gettin what im sayin
94 Dodge dakota
96 Civic ls Swapped
Previously owned
84 cilica supra
94 4 door civic
89 bmw
89 crx si
91 crx si
Old 02/05/2010, 11:32 PM   #42
nate2k5
Human Bean
nate2k5's Avatar
nate2k5 is offline
timing and fuel maps. you shouldn't have had to "tune" it. the stock fuel and timing maps are easily available online.
1989 Volvo 245
1977 Volvo 244
1978 Cobalt 19' BR
Old 02/06/2010, 07:12 AM   #43
remix Rick
remix Rick's Avatar
people told me that the maps can stop working or they can fry out... like j.s wanted to do a map on it and people told me not to. but any ways i think i have a new plan for the civic
B20/v
but here is my ? is it like the ls were you have to have a ls/v kit or is it just wam bam throw the head on and torque it down?
94 Dodge dakota
96 Civic ls Swapped
Previously owned
84 cilica supra
94 4 door civic
89 bmw
89 crx si
91 crx si
Old 02/06/2010, 09:06 AM   #44
nate2k5
Human Bean
nate2k5's Avatar
nate2k5 is offline
B20/v
either the people you talk to are completely retarded or you are not explaining what they told you well at all...you have a map on it now, all FI cars require fuel and ignition maps to know when to fire and when to inject gas. all a map is is information on the chip on your ecu.
all of the same things you have to do on a LS you have to do on a B20...
1989 Volvo 245
1977 Volvo 244
1978 Cobalt 19' BR
Old 02/06/2010, 10:12 AM   #45
Garrett
Guest
Posts: n/a
Exactly what nate is saying....Burn a STOCK PR3 map onto a chip, place it in your ecu....Its what 99% of people that have stock engines with P28 ecu's do. No reason for a tune on a completly N/A engine, unless you want maybe 2hp.....
By a LS or B20 engine....Use itt. Leave it alone. They are strong engines, You don't have to have Vtec...Most B18 non-vtec engines will be faster than B16 engines anyday...I personally in your case would buya 18/20, put it in...sell your head. You will get alost as much out of your head as you can buy a B20/18 for.. And you get SOME tq.
Old 02/07/2010, 03:13 AM   #46
Old 02/07/2010, 08:49 AM   #47
remix Rick
remix Rick's Avatar
The thing im worried about is will every thing plug stright up into the b18, i know the vtec wires will not be needed, but will every thing els match up rite, cause if i can i plan on just b20 swaping it
94 Dodge dakota
96 Civic ls Swapped
Previously owned
84 cilica supra
94 4 door civic
89 bmw
89 crx si
91 crx si
Old 02/07/2010, 11:07 AM   #48
nate2k5
Human Bean
nate2k5's Avatar
nate2k5 is offline
do some research, the b20 never was available in obd0 so you will need a conversion harness or to convert the motor.
1989 Volvo 245
1977 Volvo 244
1978 Cobalt 19' BR
Old 02/07/2010, 11:38 AM   #49
jordan_xX
jordan_xX's Avatar
I've got an Ls head for you and some other things if you wanna put together a motor.
'97 Type R
(Type Replica)
-Spoon Engine
-T-66 turbo
-Motec Exhaust
-Skunk 2 pistons
Old 02/07/2010, 12:12 PM   #50
remix Rick
remix Rick's Avatar
my car is converted to obd2 you can tell by the dizzy plugs correct ?
94 Dodge dakota
96 Civic ls Swapped
Previously owned
84 cilica supra
94 4 door civic
89 bmw
89 crx si
91 crx si
