Old 05/25/2010, 12:16 PM   #1
Duh-kneel
Duh-kneel's Avatar
Duh-kneel is offline
Default code 43
Swapped a b16 in a crx. Code 43 comes up. Replaced the fuel pump with walbro 255. Still getn Code 43.
Fuel pressure went from 35 to 55 after installed.. does it need a FPR and adjust it? Put the main relay last year and sometimes i dont hear the fuel pump whine
Any help or ideas would be appreciated. Thanks.
Los Angeles LEAKERS Purp&Yellow
Old 05/25/2010, 12:21 PM   #2
erok
F.T.C.
erok's Avatar
erok is offline
Default Re: code 43
o2 sensor.?
Old 05/25/2010, 01:20 PM   #3
Default Re: code 43
what ecu are you running ??
Code 43 is generally the Oxy sensor being lazy or dead.It's easiest to just replace it than to try and test it. When it dies, the ECU goes into default If you test it, follow the Shop manual and make sure that you use a DIGITAL MULTIMETER ONLY> Analogue ones kill sensors real quick.
¿?¿?¿?¿?¿?¿?¿?¿{-}-{},{}_{},{}-{-}¿?¿?¿?¿??¿?¿?¿ {}s0sl{}
Old 05/25/2010, 01:44 PM   #4
mycarslow
mycarslow is offline
Default Re: code 43
This is where I love my scan tool and pid list... look up to spec or rang and see if your o2 is active at all
Built h22 62mm turbo e85
Old 05/25/2010, 02:20 PM   #5
Default Re: code 43
check the fuel pressure, fuel pressure regulator or vacuum leaks. Fuel pressure should be at 42psi at idle.
Old 05/25/2010, 03:07 PM   #6
Default Re: code 43
also check the fuel filter, just unhook it and turn it up side down to see what the gas looks like that comes out(obviously poor it into a small bucket or coffee can ), I've seen alot of nasty ones.
Old 05/25/2010, 07:35 PM   #7
Jovi_Bot_3000
Jovi_Bot_3000's Avatar
Jovi_Bot_3000 is offline
Default Re: code 43
Im using a p28 that has a b16 chip in it. The motor is a b16a2, but I don't know if the chip is for jdm b16 or the b16a2....if that even matters.
I researched and code 43 said Fuel Supply System. A faulty o2 sensor will trigger that? (just clarifying)
but yeah, the o2 sensor was one I had laying around from my Acura legend that had like 170k miles on it. Fuel filter I can't remember if I ever changed it but I might as well since they're pretty cheap
Originally Posted by RICKYritethere View Post
.... All these Noobs on Jdmcity seem like Spam these days.
Old 05/25/2010, 07:40 PM   #8
Jovi_Bot_3000
Default Re: code 43
Fuel pressure gauge reads 55psi at idle. And I have oem FPR. Back before, the stock pump would give me a pressure of 35psi.
Will I be needing to get an adjustable FPR to lower it to 42psi? Correct me if I'm wrong but I thought the oem FPR was supposed to have fuel set at a specific pressure??
Old 05/25/2010, 10:10 PM   #9
Default Re: code 43
I think thats why someone recommended checking your vacuum lines, If your fpr is not getting enough vacuum it may be causing it to not open properly to return fuel hence creating higher pressure. However thats just a theory or recommendation but a good place to start. Are you throwing any other codes ?? I'd say if your vacuum lines look good get a fuel filter and a 02 sensor and reset your battery and hopefully you are good to go If that doesnt work I'd double check your 4 wire 02 sensor wiring.
Old 06/05/2010, 11:21 PM   #10
Jovi_Bot_3000
Default Re: code 43
is that with the vacuum line off during idle?
also a quick question to be sure: MY FUEL FILTER HAS BOTH THE INLET AND OUTLET HOLE ON TOP OF THE FILTER, WHICH HOLE DOES THE PRESSURE GAUGE GO OVER??
Old 06/06/2010, 12:13 AM   #11
Default Re: code 43
You can always get a B&M fuel pressure gauge and keep it on there always.....like the pic below!!
Old 06/06/2010, 12:26 AM   #12
Jovi_Bot_3000
Default Re: code 43
that bay looks similar to my crx...if it actually is, then the only difference would be ... that the fuel pressure gauge in my car is on the inlet hole instead of the outlet as shown in yours....
so is mine over the wrong hole?
Old 06/06/2010, 12:59 AM   #13
Default Re: code 43
gauge goes on the line leading to the fuel rail and not the one going towards the firewall.
Old 06/06/2010, 09:38 AM   #14
Jovi_Bot_3000
Default Re: code 43
Haha i had a feeling it might be wrong, the fuel pressure gauge was installed by the previous owner so i assumed he knew what he was doing, but i guess not.
Thanks for help!
Old 06/06/2010, 11:16 AM   #15
Default Re: code 43
Thanks for help!
Yes sir...........and as i always tell everyone, unless you know the owners extremely well never assume anything on a vehicle was installed properly. There are many guys on this site I would trust in a heart beat to install things...........and then there are those that think duct tape, glue, and hammers are the ultimate installation helpers...lol
Old 06/06/2010, 11:58 PM   #16
Default Re: code 43
Hey, what is wrong with my techniques?
Mike
Old 06/07/2010, 12:11 AM   #17
Default Re: code 43
Mike
LOL I was quoting that last part for myself....LOL I love duct tape and when mixed with glue it is stronger then JB Weld....which is why I need the hammer in case them parts get stuck together......... ha ha ha
Old 06/08/2010, 10:24 PM   #18
Jovi_Bot_3000
Default Re: code 43
My B&M Commandflo came in today. Got it installed.... BUT the lowest i can get it to is 52PSI!!! What is going on now?!?!?! Someone please help....
Old 06/09/2010, 09:44 AM   #19
Default Re: code 43
what fuel pump are you running and what is your idle rpm?
Old 06/09/2010, 10:06 AM   #20
Jovi_Bot_3000
Default Re: code 43
I am running a Walbro 255. My idle rpm at normal temp is about 900-1000ish.
I installed a new fuel filter and different O2 sensor and they pretty much got rid of my erratic idling. I think the filter was clogged or something.
But other than that, I'm unable to lower my fuel pressure from the 58psi it was at before.
Old 06/09/2010, 02:59 PM   #21
Default Re: code 43
ya, you def need a adj. FPR your stock fpr isnt going to hold up to the pressure the walbro is pushin
Old 06/09/2010, 06:57 PM   #22
Jovi_Bot_3000
Default Re: code 43
Is there ANY chance the fuel pressure gauge itself, could be the problem? maybe like giving me a wrong reading? Because im not sure how old it is, it was on the car when i bought it. I recently installed a B&M Commandflo (adjustable fuel pressure modifier) and set it to it lowest. Fuel pressure is lower but not the 42PSI i was trying to go for.
Old 06/09/2010, 07:36 PM   #23
Default Re: code 43
I would def rule out a faulty gauge before a faulty B&m fpr
I'd try a good name brand gauge or just go to a local hydrolic shop and get a good gauge
Old 06/09/2010, 08:40 PM   #24
Jovi_Bot_3000
Default Re: code 43
Yeah, I think I'll just go ahead and find a good fuel pressure gauge. I better do it quick, because now my car has somewhat of a problem trying to start-up.
Old 06/09/2010, 09:04 PM   #25
Default Re: code 43
i'd set you fpr in the middle, adjusting it to lean will cause your car not to start, put it half way out and you should fire up easy again, sound like you just got a chinese fuel gauge
