Old 09/30/2010, 03:46 PM   #1
hondaJQ
hondaJQ is offline
Default B16 year? what ecu?
Can anyone tell me what motor i have. its in a 98 civic ex with b16 swap. the block is pr3-2 and the year is 99 but has a cable clutch? it stumps me because i thought the cable cllutch came with the b16a sir motor but has that head. i need to do a new wire harness and ecu.. can anyone tell me what ecu i need and where to get a new harness?
Old 10/11/2010, 01:07 PM   #2
hondaJQ
hondaJQ is offline
Default Re: B16 year? ECU/HARNESS HELP
Anyone?
Old 10/11/2010, 01:22 PM   #3
squishmitten
squishmitten's Avatar
squishmitten is offline
well the tranny is def a hydro bro.. if it was a cable tranny then you would need a cable to hydro conversion kit from hasport.
"It's a pretty simple concept really...suck ,squeeze,bang,blow ... Repeat as necessary."
Old 10/11/2010, 01:32 PM   #4
squishmitten
Those numbers are not a reliable way of telling what year the head is or what engine it came from.
the only way to tell what year the head is, is by the circle with emobossed numbers right above the exhaust port on cylinder #4
dude im pretty sure you have a full 99-00 si b16 swap like he said.. i did a lil research and i think your safe... as is for the wiring, good luck
Old 10/11/2010, 01:34 PM   #5
squishmitten
the year is actually in picture 2 as clear as day.
it being a 99 obviously
Old 10/11/2010, 01:51 PM   #6
That is a date stamp there in the second picture. The head is from a 2000. The units are date stamped from their production run, and the production runs are from the year before, therefore it is a 2000. What is the block stamp? B16A2? Also, you have a hydraulic transmission, although it does not look like it has a VIN tag on it. It would be riveted on the transmission and would be near the block code on the front of the block. It would be green in color. Another thing you can look for is a VIN tag on the block itself. It would be on the back of the block, down by the oil pan surface. It would be green also. You could tell definite year of the engine by decoding that VIN tag. Anymore questions, just ask.
Mike
Old 10/11/2010, 02:45 PM   #7
hondaJQ
hondaJQ is offline
Thanks for the help guys.. ALOT lol. and ill take a look for the green lettering u had talked about. so probably b16a2? anyone know what ecu and the obd harness to get?
Old 10/11/2010, 04:20 PM   #8
Use the 98 EX harness for the car. As far as ECU, I would pick up a OBD1 P30 for stock. Otherwise go with a socketed P28/P06 that is chipped for a B16. To do that, you will need an OBD2A-OBD1 jumper harness.
It is not green lettering, it is actually a green tag like this.
Old 10/12/2010, 12:38 AM   #9
hondaJQ
hondaJQ is offline
[IMG][/IMG]
awsome thanks for the help.. this is the only thing i seen rivited with numbers on the front but no green tag like that.... u said i could check near the oil pan? under the car right? sorry im a newb and my first honda build
Old 10/12/2010, 02:14 PM   #10
hondaJQ
hondaJQ is offline
i seen in black lettering on the trans s4.. i read thats a tranny from the 00 civic si i think? so this is a full 98 ex to 00 si swap?
Old 10/13/2010, 06:22 PM   #11
With an S4 transmission housing, sounds like B16. Scrape the paint off of the area by the serial # there. Can't even see the block code.
Old 10/13/2010, 07:52 PM   #12
hondaJQ
hondaJQ is offline
I'm not sure what paint cuz the block isn't painted thas just the metal. The code says 1000800. If ur talking about the last picture..
Old 10/14/2010, 12:53 AM   #13
hondaJQ
hondaJQ is offline
mike thanks for the help and same to u chris lol. so for the harness and ecu.. does it matter if i get the stock ecu for this motor or is a chipped p28 better? anyone know whwat the differneces are? and im going to get hondata s300 if that matters?
Old 10/14/2010, 09:05 AM   #14
heeltoehonda
heeltoehonda's Avatar
heeltoehonda is offline
I don't think the 1000800 code is the one mike was reffering to. An example would be "b16a2". Just like in his picture it says "h22a1"
Old 10/15/2010, 12:14 AM   #15
hondaJQ
hondaJQ is offline
yea i know what tag ur talking about but theres no green tag it was taken off. can see where it was and the 2 pins that hold it on just no tag. and for the b16a2 or any other cast be sides the pics ive taken is it unless theres something under the motor or on the other side of the block
Old 10/16/2010, 01:47 PM   #16
Right above that serial # (1008000), if that is on the front of the block where I am thinking, there should also be an engine identification code. Like B16A2.
As far as the ECU, you would need to convert from obd2A to obd2B to run the factory ECU. A P28 would be better, especially with the S300.
Old 10/19/2010, 09:34 AM   #17
JDM Jake
JDM Jake's Avatar
JDM Jake is offline
i have a stock 00 si ecu if you wanna buy it.
Old 10/30/2010, 11:21 PM   #18
mr.carr
drift_kid_s13
mr.carr's Avatar
mr.carr is offline
july of 99 was the month and year casted and stamped so anything after june is concedered 2000.
Google Monster
Originally Posted by Rob Dahm
Old 10/31/2010, 09:02 PM   #19
what intake mani is that ? doesnt look like sir 1 or sirr 2 or b16a2 look like b18c5 intake mani kinda
Old 11/14/2010, 04:20 PM   #20
hondaJQ
hondaJQ is offline
Dude I'm really not sure this is my first honda know nothing all I know is I need new engine harness ecu intake fuel rail tb injectors and don't know what ones to get because I'm still trying to figure out the motor its 98 ex. I think full 2000 b16 swap
Old 11/15/2010, 12:25 PM   #21
JDM_GsR_515
JDM_GsR_515's Avatar
JDM_GsR_515 is offline
That's a JDM valve cover. USDM valve covers have Honda Motors Co and JDM has the H symbol. Just trying to provide any info to help.
Old 11/15/2010, 05:12 PM   #22
hondaJQ
hondaJQ is offline
So is that better? Thanks for the info man
Old 12/09/2010, 11:41 AM   #23
mr2boostin
mr2boostin is offline
you have a 99 b16 or b18c1 head( b16 is off a civic and b18 would be off a gsr ) - ( anything 96 and newer will be OBD2 ) the ecu's you can use are
p28 , and p72 - if you are using hondadata it dosent matter what one you get since its all going to change when its tuned and if you want to run obd1 you will need a jumper harness from obd2 to obd1 that you can find on ebay for about $50 dollars , also what car is this going into ?? and im sure your block is for a h22 and wont blot up to a bseries * if you have any other questions pm me *
Old 12/09/2010, 11:51 AM   #24
mr2boostin
look on jdm city , ebay , online for you wire harness ( if your goin obd2 get a gsr engine harness , so it has the vtec line ran ) or bring it to the shop , they will run the vtec wire if needed and have the head placed on for about 70 per hour .. takes about 3-5 hours to get the job done - wrenches in des monies is having a sale till the end of the month too
Old 12/09/2010, 11:53 AM   #25
mr2boostin
valve cover adds 100 hp has to be jdm LOL
