Old 07/27/2010, 09:15 PM   #1
1SlowEm2
1SlowEm2's Avatar
1SlowEm2 is offline
Default anyone know how to change out a slave cylinder?
LMK!. its for a 95 accord lx. F22b2 motor and yeah.
needing to get it done by friday.
1992 H22a civic SOLD
1996 Civic Traded
91 CRX Sold
94 Civic SOLD
02 Civic -- saving for a Manual Swap!
Old 07/28/2010, 04:51 AM   #2
remix Rick
remix Rick's Avatar
remix Rick is offline
Default Re: anyone know how to change out a slave cylinder?
well you take the line off, pull the slave cylider off, put the new one on, and bleed the system.... easy easy ive done it 3 times.
94 Dodge dakota
96 Civic ls Swapped
Previously owned
84 cilica supra
94 4 door civic
89 bmw
89 crx si
91 crx si
Old 07/28/2010, 05:33 AM   #3
5spdSedan
5spdSedan's Avatar
5spdSedan is offline
lol jeez didn't you ask me about this like a week ago over on facebook? lol if i was closer i would help. ok so i would start by getting all the fluid out by loosening the bleeder valve and move the clutch pedal til all fluid is gone then remove the lines and unbolt install new one the opposite of removal close the valve refill fluid, have a friend step on the clutch pedal when you say and bleed the system of any air and tighten then pump for pressure then you can rebleed if you want to check again. then refill as needed. dont forget to put the cap on when pumping for pressure. thats how i did it yesterday on a friends. just text me if you need help.
Old 07/28/2010, 09:44 AM   #4
This is off a D series but it basically is the same as what 5spdSedan was talking about Mr. Rowe....lol Hope it helps!! When you bleed it make sure there is a hose at the bleeder going into a cup full of brake fluid, this will help ensure bubbles don't go back in and you can see them come out.
Old 07/28/2010, 11:57 AM   #5
1SlowEm2
1SlowEm2's Avatar
1SlowEm2 is offline
Thanks guys, btw alex, i asked you about a MAster cylinder xD
1996 Civic Traded
91 CRX Sold
94 Civic SOLD
Old 07/28/2010, 05:40 PM   #6
5spdSedan
5spdSedan's Avatar
was it a master lol? hahaha i seriously must of lost some brain cells when i dropped a ratchet on my head yesterday well atleast i knew what i was talking about when you asked about a slave cylinder lol.
