Old 03/19/2012, 12:32 PM   #1
asianboy3t
asianboy3t's Avatar
asianboy3t is offline
Default dsm problem
what does it mean if my eclipse starts up fine but then loses rpm power and dies out? then i go to start it up and does the same thing..starts up fine then dies? any help
Old 03/19/2012, 12:36 PM   #2
lovefordsms
lovefordsms's Avatar
lovefordsms is offline
Default Re: dsm problem
boost leak,fuil pump, but i would think boost leak more then anything.
Old 03/19/2012, 12:48 PM   #3
asianboy3t
asianboy3t's Avatar
so would it b the hoses running to my blow off valve?
Old 03/19/2012, 01:10 PM   #4
arsalan500
arsalan500's Avatar
arsalan500 is offline
im the guy who called you about the car,
most likely its a boost leak, if you wanna drive the car to my house, I can take a peak at it.
LMK
1995 Eclipse GSX(Project Rebuilding)---------------Still Own
1995 Eclipse Gst(Good Dsm)-------------------------Still Own
1994 Honda civic, b16 swap, Blacked out-----------Still Own
1997 Nissan maxima (rebuilding)--------------------Still Own
Old 03/19/2012, 01:27 PM   #5
asianboy3t
asianboy3t's Avatar
wish i.could..lol but wont stay started long enough to drive? starts and rpm goes up like normal as it would when u normally start a car. but then rpm will go down and die out? doesnt matter if i step on the gas or not? fuel filter?
Old 03/19/2012, 01:53 PM   #6
pirate
pirate's Avatar
pirate is offline
start simple.. is the battery any good.. high idle? or it just dies after starting..does the idle hang?
www.facebook.com/syn-customs
Old 03/19/2012, 02:01 PM   #7
asianboy3t
asianboy3t's Avatar
no high idle. just starts up normally with no problems and rpm rises like normal upon starting then slowly loses power and goes down and dies?
Old 03/19/2012, 04:36 PM   #8
lovefordsms
intercooler lines the hose going to the bov is the maf hooked up just stuff like that.
Old 03/19/2012, 04:39 PM   #9
asianboy3t
asianboy3t's Avatar
okay bcuz just recently i changed the oil..spark plugs..and put in a new alternator..do u think it could b a fuel filter being clogged or dirty?
Old 03/19/2012, 06:12 PM   #10
lovefordsms
could be change that itss only 10 bucks but im still thinking boost leak
Old 03/19/2012, 06:59 PM   #11
91efcivic
91efcivic's Avatar
91efcivic is offline
im thinking fuel problem... boost leaks will still let the car idle. sound to me its getting the fuel pressure built up when u turn the key on but there is not enought flow to keep the car running.. u might have a small pin hole in one of the fuel lines which will suck air but will not cause a leak just a big drop in fuel pressure. any more questions please feel free to text me.
Thanks,
Matt Franks
(319)981-2082
Old 03/19/2012, 07:49 PM   #12
lovefordsms
i guess you havent had many dsms i can show you one right now with no pipping on it and it wont idle ask anyone on this site about a boost leak dude.
Old 03/19/2012, 07:55 PM   #13
you guys hear snooki's pregnant?
Old 03/20/2012, 03:16 AM   #14
louie
louie is offline
A boost leak and missing pipes are two different things. I have had plenty of cars that I've worked on that started out with mild to major boost leaks and they ran without dying.
Last one I had do this the pump was dying out. It would run for maybe 10 seconds.
Old 03/20/2012, 05:42 AM   #15
91efcivic
91efcivic's Avatar
Thank u. iv owned my share of DSM's not to mention iv worked on A LOT!!! of turbo'd cars. and O'yea do i have to throw out the ASE/honda/nissan/subaru certifications? and FYI there is a video of sheps talon running just fine with no/non/0 charge piping hooked up.
Old 03/20/2012, 01:09 PM   #16
asianboy3t
asianboy3t's Avatar
thanks everyone for the help i figured it out..i went through the motor and checked alll my hoses and sensors amd came across my intercooler somehow came unplugged and i got it plugged back up and now the car starts and runs great..so yeah i guess air/boost leak..hope i didnt ruin anything like my turbo? thanks a ton everyone again i was this close to selling this car for dirt cheap as a parts car
Old 03/20/2012, 04:22 PM   #17
lovefordsms
your welcome i guess mr ase was wrong and some guy that dont know crap was right
Old 03/20/2012, 04:36 PM   #18
91efcivic
91efcivic's Avatar
must be rinning the poor mans MAF.. huh?
Old 03/20/2012, 04:45 PM   #19
louie
louie is offline
The ic pipe was completely unhooked, he didn't even need to do a blt lol. Guess we should ask if he whistled and sprayed soapy water on his mouth as he did a visual check.
Old 03/20/2012, 05:57 PM   #20
91efcivic
91efcivic's Avatar
LMAO!! i love it
Old 03/22/2012, 08:30 PM   #21
gooseberry09
gooseberry09 is offline
never heard of that happening before :/ good to know
Old 04/01/2012, 11:14 AM   #22
yamaha
yamaha's Avatar
yamaha is offline
I have to agree with ase man lol a boost leak will still idle but a completely removed pipe will not.
Old 04/01/2012, 12:08 PM   #23
lovefordsms
Thread is old read the dates
