Old 05/09/2012, 04:07 PM   #1
yamaha
yamaha's Avatar
yamaha is offline
Default 97 eclipse rs tranny problem
My buddy said when he tries to shift from any gear to 3rd it grinds a little and 3rd is the only gear it does it in sounds like a synchronized but does anyone know for sure and if so where to get one
87 supra turbo-project
95 dsm gsx-sold
95 eclipse gs-sold
Old 05/09/2012, 08:37 PM   #2
Default Re: 97 eclipse rs tranny problem
ive had the same exact problem, i got another trans for 3hundred dollars swapped it in an fixed my problem, not worth fixing synchro's imo when u can get trans for these dirt cheap
Old 05/19/2012, 02:16 PM   #3
jeff_95talon_tsi
jeff_95talon_tsi is offline
most of the time when it grinds in one gear either one your low on fluid or your gears could be going bad it's easy fix i would tell him to check his fluid first i mean if it's low then it will grind common sense kinda good luck with it though
