Go Back   JDMCITY.COM > Technical Forum > Do It Yourself (DIY)
Old 05/18/2010, 11:32 AM   #1
.saint
JDM Fan
.saint is offline
Default [*diy*] ek9 honda civic side marker install.
i do not take credit for this how-to. this is a port from another site witch was then ported from my site, figured it would be a good how-to to have floating around the site.
Originally Posted by rvm
You should follow this template:
Photo of the placement on the fender, 155 mm from the top of the molding to the bottom of the tape and 140 mm from the edge of the door to the edge of the tape.
Find the center of the intersection, which is where the exact center of the sidemarker:
Then findd the center of the template and line up the two over each other and tape it down:
A drill was used to make the initial hole, then you can use a metal nibbler from RadioShack:
The final hole:
After cutting the hole, add some touch up paint on the bare metal to help prevent rust.
Wiring begins:
There are two wiring options. JDM (Sidemarker only blinks when turn signal is on) or USDM (Sidemarkers stay on and blink alternately with the signal).
Pull back the fender liner and remove the corner/parking light. There will be 3 wires going to the bulb. Tap into the corresponding wires for each blinking style.
JDM:
Tap into green(turn signal) and black(ground) wire.
USDM:
Tap into red(parking light) and green(turn signal) wire.
Now side markers are in!
Use this photos to compare with the oem ek9 side markers installed in a EK9. I see them 98% perfect.
OEM JDM EK9 Honda Civic Type R Side markers:
Recommendations:
Use a spare fender to test first!
If you don't have patience, don't do it.
Remember to put some touch up paint in the hole to avoid corrosion.
Keep in mind that in certain USA states, and other countries; you can get pull over by the cops if they want because of this modification.
Additional Measurements, just in case you have any doubts:
[.saint works] is coming soon!
.saint, the rolling honda EK parts jdMuseum.
dabears straight up kills it! poop.hell sideways.brigade
i shaina. forever in my heart.
Old 05/18/2010, 01:40 PM   #2
Bun
Bun's Avatar
Bun is offline
Default Re: [*diy*] ek9 honda civic side marker install.
or you can just call our legendary GABE
B18C1
Sol
Old 05/18/2010, 03:36 PM   #3
importsusa
Vinyl Specialist
importsusa's Avatar
importsusa is offline
Definately X2 on that..........
just whatever you do don't give it to Ben here.....you'll end up with a 42in. hole on the side of your fender, door, rear quarter panel and some ambulance strobes shoved in there with masking tape!! ha ha JK BEN...or AM I!!! ha ha ha
Great write up as well to have .Saint, keep it up............we need more of these circulating around!!
come check us out..............
Old 05/18/2010, 04:19 PM   #4
.saint
JDM Fan
.saint is offline
didnt realize you guys had a local side marker cutter :P haha
there is nothing better then attacking your fenders with a dremel or nibblers :thumbup:
Old 05/18/2010, 07:09 PM   #5
ChunKy
my mexico
ChunKy's Avatar
ChunKy is offline
yup GABE did alot fenders for local! i rather pay small fee have a experienced person do it then f'ed it up and need get new fender or need repair fender and paint it later on
blah
Old 05/18/2010, 11:05 PM   #6
Bun
Bun's Avatar
Bun is offline
haha i can do a mad tyte jdm ambulance light up deal on your sol chunky ask rodnie =] btw your sol looked pretty good when i saw it chillin at chens for like a year.
B18C1
Sol
Old 05/21/2010, 01:19 AM   #7
nateridesbikes
nateridesbikes is offline
installing my side makers was the most nerve racking thing ive ever done. i used this exact diy and everything is good and gravy. i think a dremel is a better tool to use tho if anyone wants to take a stab at it.
Old 05/21/2010, 12:50 PM   #8
deadmoans
deadmoans's Avatar
deadmoans is offline
Practice on some scrap metal first with the dremel so you get the hang of it. Some of those round bits for steel can get away from you and next thing you know you got a nice line cut but it's half way down your fender.
But whoever said earlier was right....patience.
Cheap, Fast or Reliable, You Can Only Choose Two.
Old 05/21/2010, 01:00 PM   #9
nateridesbikes
truth
I put at least 5 holes in an old fender before i got it right.
Old 06/01/2010, 10:19 PM   #10
gabebauman
DR. DIY
gabebauman's Avatar
gabebauman is offline
Wrench Re: [*diy*] ek9 honda civic side marker install.
Yes...that is a great write-up. Best thing about it is it has measurements and pictures. I've never used a nibbler, (I don't have that kind of spare time), I've always used a dremel with cut-off disks. Word of caution though...tape off the fender real good, make a cardboard template so you can test fit your side marker in that and then be able to trace it onto the tape on the fender, start small, cut, test fit, cut, test fit, cut, test fit, etc. A steady hand is a must with a dremel, I'm talkin' hold that puppy tight...don't let it get away from you.
If you don't feel comfortable doing them yourself...bring them to me...I'll be glad to do them...for a small price of-course.
FOR SALE> http://www.jdmcity.com/showthread.php?t=3858
CLICK IT> http://gabusface.blogspot.com/
PS: I cut holes in fenders...pm me.
Old 06/06/2010, 06:03 PM   #11
passwordjdmef9
Still Shreddin'
passwordjdmef9's Avatar
passwordjdmef9 is offline
i dropped a set of ej8 fender's to gabe on friday to have the sidemarkers installed. got them back a day earlier than expected, and they look great. thats the second set of fenders hes done for me, and i recommend anyone wanting these to send em to gabe, he'll take care of ya.
my 88 BSM ef9 build thread http://www.jdmcity.com/showthread.php?t=9411
Originally Posted by alexbuck205 View Post
.. wanna have a beat off?
Old 08/04/2012, 07:31 PM   #12
chonfop
chonfop is offline
A couple things:
1. Cover the entire fender area with with paper/tape. This helps when you lose control of the dremel. Trust me it will happen.
2. Always anchor your hand against the car before pressing in with the dremel, so you don't lose control.
3. Be patient!!!! Go slowly and remember to anchor.
4. The guide here says 155mm, but I'm pretty sure it's actually 125mm. Look at the picture, it lines up with the top of the wheel well. Just make sure yours lines up with the top of the well too.
5. Don't force the light in there or you'll bend the fender. Just be patient and widen the hole.
6. The car paint might peel so watch out for it and remove any tape around the hole slowly.
7. BE PATIENT AND CAREFUL.
Old 10/12/2012, 09:42 PM   #13
92AcuraGSR
92AcuraGSR is offline
Very nice work, Will these measurement work on a 1992 Acura Integra?
Old 10/15/2012, 08:47 PM   #14
crxh22honda
crxh22honda's Avatar
crxh22honda is offline
Originally Posted by HankHill View Post
gabe, how much you charge?
Pm him. An how did a 2 year old post get bumped.
Old 10/16/2012, 06:26 PM   #15
Pancho
Pancho's Avatar
Pancho is offline
this is how.. lol
Originally Posted by chonfop View Post
A couple things:
92 Civic Hatch SI [Sold]
92 Talon Tsi AWD[Sold]
93 Civic Hatch SI [Sold]
Old 10/05/2017, 03:03 AM   #16
tech54K
tech54K is offline
Thanks for this. Really helpful.
