Old 11/04/2005, 08:51 PM   #1
HANDA
HANDA's Avatar
HANDA is offline
Msg FAQ: Car Won't Start/No Spark/Etc
(From experience and from what others say)
It cranks but, no spark?
Fuses - First things first, check all fuses to see possible blown ones. If so, replace them with right amp fuses.
Distributor - Your distributor may be out. Or some of its internals such as coils, ignitor, etc may be out. Best to get the same distributor somewhere and try it on your motor to test if yours was bad. If so, replace it or fix internals.
Spark plugs & wires - Spark plugs may be worn. Try new or known working spark plugs. Check wires with a multimeter for proper voltage.
Ground - One of the main problem. Make sure your motor is well grounded all around, especially by the thermostat housing!
more to come....please add some more!
Old 10/18/2008, 11:21 PM   #2
turborex
turborex's Avatar
turborex is offline
Default Re: FAQ: Car Won't Start/No Spark/Etc
YOUR MAIN RELAY- usually located underneath the steering column- labeled MITSUBA and this controls your spark and fuel your ground to the ecu and fuel pump.
Old 01/01/2009, 10:29 AM   #3
68cam
68cam's Avatar
68cam is offline
my car wont start just changed wires checked plugs and dizzy looks good
but my o2 sensor wiring is all F@#$ed up please help
"The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so damn temperamental."
Old 01/09/2009, 09:52 AM   #4
turborex
turborex's Avatar
turborex is offline
does it got good compression, does it crank over, does it got spark and fuel. all you need to find out to get it working. and sequence
