Old 03/01/2010, 10:53 PM   #1
91civicsi
91civicsi's Avatar
91civicsi is offline
Default desol starting pro
ok got a del sol vtec trim so has the stock b16a3 in it had bad oil pan gasket and replaced and now it wont start had trouble starting befor i changed it but it still started but now nothing has a week spark put new plugs and wires on it but still wont start any thoughts ppl
Old 03/01/2010, 11:28 PM   #2
Default Re: desol starting pro
What all besides what you noted have you check..... as in is battery fully charged, have you checked spark...etc, etc.
I can give ya a small check list but it'll be hard determining what the issue is from where i'm sitting...lol
Old 03/02/2010, 12:06 AM   #3
91civicsi
91civicsi's Avatar
ok the spark is like week but i just took the battery off the charger it says good but the other night when i bought it i trailer'd it home but i my garage is on top of a hill so i drove it off the trailer and up in to my garage and it drove fine just leaked oil from the bad gasket ive checked all the things a could think of fuel air spark
Old 03/02/2010, 12:42 AM   #4
aight, i'll Pm you some stuff to look into to see what else it could be.
Old 03/02/2010, 08:19 AM   #5
RyanA
RyanA is offline
Fuel, compression, and fire (in correct time) is all you need to run. To make it simple, spray some carb cleaner in the throttle body and see if the injectors are firing. If the car starts after you do this, you have a fuel issue. If it still does not start, you probably have a spark, timing (mechanical or plug wires on wrong), or compression issue. do you hear the fuel pump cycle? If not, crank the engine and smack the side of your dash at the same time. Hit it multiple times while cranking. If the car starts, pull your main relay and reflow the solder joints.
Ryan
Old 03/03/2010, 11:40 PM   #6
91civicsi
91civicsi's Avatar
fixed it pro with dizzy
Old 03/04/2010, 12:54 AM   #7
GOOD DEAL MAN.........so what all was wrong with the Dizzy? replacement, cleaning, was it a little off....etc.
Old 03/04/2010, 08:20 AM   #8
nate2k5
Human Bean
nate2k5's Avatar
nate2k5 is offline
seriously work on your title...
1999 Ford Expedition
1989 Volvo 245
1977 Volvo 244
1978 Cobalt 19' BR
Old 03/04/2010, 08:49 AM   #9
LOL....first time i read it I thought it said diesel starting probe....LOL
