Old 04/25/2010, 01:26 PM   #1
8==D.S.M
8==D.S.M is offline
Default Wiring...
Ok so i just got a 1989 crx si with a b16a but its got a major wiring problem but at the same time i have 1992 integra with a b16a2 and i was wondering if the wiring from my integra would work in my crx??????
Let me know asap...
Thanks james
Old 04/25/2010, 02:08 PM   #2
Default Re: Wiring...
depends on wat obd it is, your civic will be obd-0 but integra since its a 92 it might be a obd-1, convert you car to which obd the motor is, its much easier
Old 04/25/2010, 02:12 PM   #3
whats the major wiring problem ??? and which do plan to replace. just the engine harness or engine and dash harness ??
and is your teg obd-1 ?
Old 04/25/2010, 03:45 PM   #4
8==D.S.M
8==D.S.M is offline
Well my crx it wont start and when i try i get smoke coming from under the dash and the guy i got it from says that if the fuse is in for the radio it wont start but if its not then it will start and idk shit abt wiring so i want to get the crx going so can my teg wiring harness work on my crx????
Old 04/25/2010, 03:46 PM   #5
8==D.S.M
8==D.S.M is offline
Both dash and engine harness and idk my teg is a 92 with a 95 si ecu but idk if it has a jumper harness
Old 04/25/2010, 03:54 PM   #6
no you cannot use the integra one is completly different obd's
y dont you just remove the radio harness if thats whats causing the short ?
did you take the radio fuse out of the fuse panel ??
I'd take your crx dash out and narrow down the problem, to put a new harness in you will have to take it out ne ways ...
Old 04/25/2010, 04:19 PM   #7
8==D.S.M
8==D.S.M is offline
Yea and it still wont start adn i hate dealing with wiring i would rather buy a new harness or something
Old 04/25/2010, 04:32 PM   #8
either way take your dash out!!!!
how are you going to swap a engine harness and a dash harness without messing with wiring ??? LOL
buy a new non nigger-rigged dash harness if you feel like you cant fix it your self and tell the guy you bought it from he is a jackass
Old 04/25/2010, 04:39 PM   #9
8==D.S.M
8==D.S.M is offline
Im going to get a harness they have a ef hatch si that ill take the harness out of thanks for your help
Old 04/25/2010, 05:01 PM   #10
is your crx a si ?
edit: nevermind i seen in your original post it is a si.. you should be good to go with the new harness
