Old 11/15/2012, 11:22 PM   #1
2000civicsi
2000civicsi's Avatar
2000civicsi is offline
Default engine prob
So i was driving my car and then all of a sudden the motor starts cutting off like it was out of gas amd stalls (but i had half a tank still and the fuel pressure is good). I go and try to drive it again and it wont let me go past 3000 rpm on any gears (or nuetral) and revs way too high (2500 rpm) when it is idling. I checked the tps and the map sensors and they read fine on the volt meter. I also checked the timing belt and made sure its not off of tdc and thats fine. Im running out of ideas and need help cus i had my car running and now its just sitting in my garage......helppppppp
Old 11/16/2012, 12:32 AM   #2
Default Re: engine prob
plugs? wires?
Old 11/16/2012, 12:45 PM   #3
Are you running on stock ecu or a chipped one?
Old 11/16/2012, 01:26 PM   #4
2000civicsi
New distributor, new plugs and yes its a stock ecu but i dont have anything like turbo in the engine
Old 11/17/2012, 12:48 AM   #5
After the new parts.... does it run better or same? Try throwing a bottle of seafoam into the gas tank and fill her up. Run the car till gas tank is almost empty. Just to clean it out
Old 11/20/2012, 02:39 PM   #6
Need more details. Any check engine codes (I can almost guarantee you there is one)? When it hits 3k rpm what is it doing? Bouncing or simply just stalling at that rpm? During rev up is it sputtering or revving normal?
Old 11/21/2012, 03:41 AM   #7
2000civicsi
During rev up when it hits 3k rpm then it starts to bounce up and down almost like its redlining and it does spit up as well. As far as the code goes i havent checked cus theres no check engine light on but i well check it next chance i get
Old 11/21/2012, 09:13 AM   #8
Check to see if the cel bulb is still good and not burnt out
Old 11/21/2012, 08:28 PM   #9
2000civicsi
Im not to worried about the cel bulb but i am more concerned abiut my engine but i will look into thst too tho
Old 11/23/2012, 08:20 AM   #10
That bulb being out if it is out should be your number one list of concerns right now.
One of two things are happening, 1 your in limp mode due to there being something wrong such as bad sensors, or even an actual mechanical problem going on and your sensors reading it.
2nd possibility would require that you have launch control setup on a tuneable ecu and your speed sensor came unplugged or broke.
Old 11/27/2012, 11:44 PM   #11
2000civicsi
Wierdest thing happened today i went and started my car and it was fine??? I hadnt did anything to fix it yet but im confused now. I also drove it and it was fine too. Im puzzled cus last week it was doing all that weird stuff i said earlier
