Old 12/12/2009, 04:50 PM   #1
Cyberwaste
LURKIN
Cyberwaste's Avatar
Cyberwaste is offline
Default is this bad?
that boot came off i just noticed it and im not really sure what its for and i dont feel any dif in driving (it dont shake or pull)
it on my 95 civic ex its the drivers side
and also my rear windows weather stripping is coming up
do i have to take it to a window shop or can i put it in myself??
http://imgur.com/N3ABL
Old 12/12/2009, 05:01 PM   #2
eg_si
eg_si is offline
Default Re: is this bad?
mine began to do that also.
Old 12/12/2009, 05:22 PM   #3
it isn't horrible, but you do want it fixed before all the grease comes out of them. Just get a new axle or used one with a good boot on it. As for the weather stripping, you can try tackling it yourself or for a factory seal just take It down to a car window place. This way if it breaks you can have a new one put In.
Old 12/12/2009, 05:25 PM   #4
Cyberwaste
LURKIN
Cyberwaste's Avatar
ah sorry its part of the rack and pinion
sorry i took the pic really close lol i will take another
Old 12/12/2009, 07:08 PM   #5
Ya the axle is def 6-8 inches behind that rack and pinion there... just get a new one or good condition used one.
Old 12/12/2009, 08:45 PM   #6
ohh shoot, sorry didn't see that....i was looking at the picture on my phone and it just looked like an axle....LOL
Yes, either way replace this.........you don't want it getting all that snow and junk in there and damaging more stuff. If you need any kind of diagrams on how to get it out, let me know.....if not take it somewhere and get it done, just remember you'll pay more that way depending on who does it.
Thanks for the correction ososlohatch........now that i've looked at it on our laptop I can definately seethe rest of the stuff...LOL
Old 12/12/2009, 09:00 PM   #7
Cyberwaste
LURKIN
Cyberwaste's Avatar
hmm any help on the part would be nice and any ideas about my second question?
Old 12/12/2009, 10:51 PM   #8
raise and support vehicle, if you are doing this outside....wear a coat its gonna be a cold one for ya..LOL
remove wheel on affected side.
remove the cotter pin and nut from outer tie rod.
mark the placement of the nut on the inner tie rod.
remove the outer tie rod and nut.
remove the clamp from the inner and outer sides of the boot.
pull the boot off and replace with new boot.
reinstall all parts and definately make sure to get your alignment checked to make sure everything is good.
Sorry, not pictures.....if in doubt just get a chilton/haynes manual....may possibly have pics or someone in here might have pics they can show you.
As for the weather stripping, check to see if there are nay clips holding it in.....don't remember if it does on the rear window!! If need to, post pictures so we see what is going on and maybe have a couple ways we can help you fix this issue.
Old 12/13/2009, 09:31 AM   #9
91da
JDM BALLER
91da's Avatar
91da is offline
Sometimes on thoes u can just replace the boot if not u will more than likely need to take tie rod ends and everything off.
91 Acura Integra Dohc Vtec
94 Honda Civic EX Sohc Vtec
95 Honda Civic CX H22
07 Honda Civic SI K20 Vtec
07 GMC Denali
74 Monte Carlo Figure 8 car
Old 12/13/2009, 02:45 PM   #10
heeltoehonda
heeltoehonda's Avatar
heeltoehonda is offline
i'm replacing my rack and pinion boot right now. i don't think there is any other way to do it without removing your tie rod ends. the hole on the boot won't fit around the outer tie rods.
while you have everything taken apart look at your tie rods. if they look there is any wear and tear you might as well replace those also. they are only 20 bucks a side. and its one of those parts that really sucks ass if it breaks while your driving down the road.
and just like rodnie(importsusa) said.. DON'T FORGET TO CHECK YOUR ALIGNMENT
Old 12/13/2009, 06:04 PM   #11
Is it the rear window, or one of the rear side windows? The strips on the rear window are replaceable. PITA though. The side windows require replacement of the whole window. The seal cannot be purchased separately. Hope it helps.
Mike
Old 12/13/2009, 10:40 PM   #12
Cyberwaste
LURKIN
Cyberwaste's Avatar
Mike
its the back one not the sides and what does PITA mean????
and do you think my car will be fine to drive for 2weeks untill i get paid again??
Old 12/13/2009, 10:45 PM   #13
Pain In The Ass - PITA
You should be fine. Just don't let the boot go all winter.
Old 12/14/2009, 03:39 PM   #14
yea you'll be fine ... but like he sai dont let it go all winter... once you get snow/salt in there it'll start going fast...
Old 12/14/2009, 04:18 PM   #15
Cyberwaste
LURKIN
Cyberwaste's Avatar
alright cool guys thats for your helps
but im still waiting for the window thing
Old 12/14/2009, 04:44 PM   #16
Depending on how bad the strip is, you can always go down to the autoparts store and get yourself a tube of 3M trim and badge adhesive. It should be a black tube with red letters. Once you get that on there, make sure you shove the seal back In place and put something over it to apply heavy pressure. This will keep it in place for awhile, like I said before though l, if you are unsure just take it to a window place....might save you some money In the long run.
Old 12/15/2009, 04:46 PM   #17
Cyberwaste
LURKIN
Cyberwaste's Avatar
would a picture help with the window thing?
and i think i went to the the parts store and tryed getting the weather strip and they told me a auto glass co. has to put it in
Old 12/15/2009, 04:51 PM   #18
Not always the truth, just look at It and see if It Is something you want to tackle.....if It Isn't, then go to a window glass place....check for prices around the area....some places like to charge way more then needed for something like this.
Old 12/16/2009, 03:21 AM   #19
Cyberwaste
LURKIN
Cyberwaste's Avatar
well think i will just look around i dont really want to do it my self
thanks
btw this site takes a shit on H-T
Old 12/16/2009, 01:37 PM   #20
RICKYritethere
Work
RICKYritethere's Avatar
RICKYritethere is offline
Do you think my car will be fine to drive for 2weeks untill i get paid again??
That boot looks iffy, but goodluck. Replacing that will be much more of a pain with all of this snow and cold weather. You should bring it over to importUSA and get it done,
Old 12/16/2009, 01:50 PM   #21
Cyberwaste
LURKIN
Cyberwaste's Avatar
i would bring it to imports but its like a 4 hour drive
Old 12/16/2009, 03:39 PM   #22
I have the same problem, bad thing is I think i have to replace the whole rack from the same reason.
I think any Honda dealers sale them, I've tried O'reillys and other auto part's store.
Old 12/16/2009, 04:41 PM   #23
I know man, that's why I figured it best to try helpin ya out through here...LOL. it'll only be a simple install as long as you got the right tools and most of all....some patience.
Old 12/16/2009, 07:58 PM   #24
TwokSiR
TwokSiR's Avatar
TwokSiR is offline
Ducktape ftw
Looking for hydro B16 trans parts. Let me know if you have a parts transmission.
Old 12/25/2009, 09:40 PM   #25
Cyberwaste
LURKIN
Cyberwaste's Avatar
ok well also my car has ps and if i dont want it will i have to get a dif rack and pinion
ok i know this is a dumb question but yeah if i can just buy a whole r/p i will and say fuck ps and fix two things at once...kinda
