Old 12/17/2009, 04:25 PM   #1
christweek!
christweek!'s Avatar
christweek! is offline
Default problem with dpfi crx need help lol
i have everything hook up but when i go to turn the key it makes a buzzing know noise inside the car by the fron driver speakers and then nothing happens, it wont turn over or anything. can someone help thanks
ASK ME ABOUT MY BOLT ONS!
Old 12/17/2009, 11:58 PM   #2
high_octane
high_octane's Avatar
high_octane is offline
Default Re: problem with dpfi crx need help lol
make sure all your ground are all on. there should be one on the tranny and motor.
J.S AUTO SERVICE
HEY GOT ANY AXLE NUT FOR A TRANNY SPACER. DONT FOR GET TO PUT THE PRESSURE PLATE BOLT BACK ON
Old 12/18/2009, 12:02 AM   #3
christweek!
yea lol i just did that and it turns over now lol, but it sounds like the starter isnt getting enuff power to really turn it over and start.
Old 12/18/2009, 12:11 AM   #4
Main relay is the buzz, check t-stat ground, if cranking slow, throw a jumper on it and see.
Mike
Old 12/18/2009, 12:13 AM   #5
christweek!
yea lol it stopped the buzz and it is turning slow and i used a jumper and it does the same thing lol, it sounds like the starter isnt getting enuff power .
Old 12/18/2009, 02:52 PM   #6
jdmb16crx
jdmb16crx's Avatar
jdmb16crx is offline
take the dpfi motor out and throw it in a dumpster!problem solved..
Old 12/18/2009, 04:03 PM   #7
christweek!
yea lol, need it done lol it turns over, but when i hok\ok the battery ground up on the tranny it turns for a second and then some kind of power cuts it off and stops it from turn, then my ecu is thowing a ecu code, 20,
Old 12/18/2009, 04:28 PM   #8
jdmb16crx
jdmb16crx's Avatar
what code is that?
what ecu are u using?
Old 12/18/2009, 05:34 PM   #9
electrical load detector .. have fun make sure your fuse box is all hooked up.
Old 12/18/2009, 06:10 PM   #10
Like I said, did you check the thermostat housing ground?
Old 12/18/2009, 07:05 PM   #11
christweek!
yea i check that its hook up, there is two wires to that tho, ones the ecu ground and the other wire idk what it is, it does something with the fuel pump, but its give power to it,
Old 12/18/2009, 07:19 PM   #12
christweek!
could it be the main relay thats keeping it from starting the car,
Old 12/18/2009, 10:48 PM   #13
Hey chris, that could possibly be the Issue. Generally when they go bad it could be because one of the connections inside may need to be soldered. Just to cancel that out of the list of possibilities, take it out and open It and solder everything once over or whatever looks like it needs it. Many of these contacts can have very small to the eye fracture lines. My DA had a similar issue not too long ago.....also check any surrounding wires for any type of damage.
Most people think this would be just a waste of time and Unnecessary....in my opinion, it just crosses another possibility and ensures that part is still in good working condition either way.
Old 12/19/2009, 11:58 AM   #14
christweek!
alright thanks man, ill take it out and try it.
Old 12/20/2009, 05:22 PM   #15
christweek!
im going to solder the main relay tonight and then try and start it hopefully it starts,
i know that im getting fuel and spark, and compression but hopefully its just the main relay.
Old 12/20/2009, 10:50 PM   #16
christweek!
i tried it and t didnt work lol, i wish that was it, still going to try some more stuff, going to get another motor just in case
Old 12/22/2009, 08:06 AM   #17
christweek!
i got the car to start but its getting too much fuel now lol,
Old 12/22/2009, 09:14 AM   #18
Have you checked some of the wiring under the dash for damage? It could of maybe been that you moved something in there and it made contact etc. I figured I'd tell ya that because it is what happened to me...previous owner had fiddled with one or the harnesses and would almost show the same signs of what you got.
Either way just keep going....you'll find the Issue soon!!
Old 12/22/2009, 10:56 AM   #19
christweek!
i havent yet lol, but i will check and see, that could be the problem, thanks
Old 12/23/2009, 04:45 AM   #20
christweek!
got the car running, well i didnt lol, matt did, thanks matt
