Old 02/15/2012, 12:09 PM   #1
8==D.S.M
8==D.S.M is offline
Default boost issues..
I just bought a 93 integra turbo. Well its running off of the wastegate spring (8psi) but under full load it reads 4 psi. So I'm wondering what could be the problem. My first guess would be a boost leak. I have yet to look at it cause its been cold out. But I was wondering if there is any other problem? Like low oil pressue or anything..
Thanks in advance James
Old 02/15/2012, 03:28 PM   #2
Default Re: boost issues..
Boost leak is definitely a possibility. Another one could be the size of the turbo and the amount of air the engine can move. Is this at WOT and high RPM, or does it never get above 4psi?
Old 02/15/2012, 09:11 PM   #3
8==D.S.M
8==D.S.M is offline
Ill check for boost leaks... The turbo is just a t-25.. And under WOT is when i notice the 4psi
Old 02/16/2012, 12:04 AM   #4
XcreatonX
XcreatonX is offline
Like Mike said I would check boost leaks, vacuum lines, seals. If the turbo is on the smaller side it just won't move enough air up top to hold boost.
Support Iowa run corn
Old 02/16/2012, 09:25 PM   #5
when the key is off, where is the needle for your boost gauge sitting? if it's not at zero, gauge is bad. i mention it because i have seen this a lot.
Old 02/16/2012, 10:07 PM   #6
8==D.S.M
8==D.S.M is offline
The car came with a Harbor Freight boost gauge and when it is off it the needle is in the VAC side not 0.. I have a new one i need to install just havent done it yet.
Old 02/18/2012, 10:17 PM   #7
so there's the issue.
Old 04/12/2012, 03:31 PM   #8
Old 05/09/2012, 11:38 AM   #9
Clinical
Clinical is offline
definitely is boost gauge then, just swap vacuum lines to another and it should tell for sure.
