Old 11/18/2012, 11:00 PM   #1
Default running rich
it idle i am running rich as can be going from around 10.0-11.2 on my wideband, the same when im cruising regularly, but once i start to try to go into boost it starts to get lean and cuts out, the car was running pefect before and had a solid tune, any ideas what could be going on? Im running a portfuler so i should defintly not be running this rich at idle or without being in boost,
Old 11/19/2012, 09:40 PM   #2
one_slow_ej
one_slow_ej's Avatar
one_slow_ej is offline
Default Re: running rich
Timing belt slip a tooth? Ignition timing off somehow?
used parts, general maintenance, swaps, dyno tunes.
95 civic dx.. 6.9@104mph 1/8 mile
Old 11/19/2012, 11:20 PM   #3
Hondacaped
Hondacaped is offline
Ha ha Sean u know things about dsm lmao
Old 11/20/2012, 07:54 AM   #4
his shop did tune my car, and did a very nice job
but no i dont think its timing, whatever it is happened when the engine bay got powerwashed,
Old 11/20/2012, 02:25 PM   #5
Why would you powerwash your engine bay???? There's a nice lovely list of things you could have caused to go wrong.
Old 11/20/2012, 03:00 PM   #6
cus im stupid
and i know we have changed all sensors and everything, cant seem to still even get it to run right out of boost, then soon as i start to get it a little throttle it hesitates and pop's and crackles, just cant seem to figure it out,
Old 11/20/2012, 04:22 PM   #7
DSM4LIFE
DSM4LIFE's Avatar
DSM4LIFE is offline
all your intake hoses hooked up?
Old 11/20/2012, 04:35 PM   #8
yup, ive checked everything i can think of,
Old 11/20/2012, 05:03 PM   #9
Are you MAF, AFM, or MAP based? I can see blasting a maf or afm sensor causing a problem like that. Other then that I dont know how picky the other sensor are on DSM's.
Old 11/20/2012, 05:30 PM   #10
DSM4LIFE
DSM4LIFE's Avatar
DSM4LIFE is offline
you replace your TPS sensor?
Old 11/20/2012, 05:31 PM   #11
Swapping out maf will be my next step, and ya dsm sensors can be very picky,
Old 11/20/2012, 09:42 PM   #12
ok, i took of my missing link tonight and it went from running rich at idle to lean, so it tells me ive got an exhaust leak because once i start going it goes back to normal around 14.0's, so now just got to fix the leak then order a new tuner and tune again, hopefully big things out of this car in 2013,
Old 11/21/2012, 08:50 AM   #13
Why in the world are you running a missing link? Especially when you have a tuneable ecu. Rip that shit off there, it'll solve a lot of your problems.
Old 11/21/2012, 09:05 AM   #14
This is for a 420a not a 4g63t, with out a missing link if the car sees boost it will kill the maf,
