Old 08/21/2013, 11:44 AM   #1
Default BOV are just a flashy noise?
In the past 2 years it's come to my attention that maybe BOV aren't the "turbo life saver" like we all have come to believe. I've noticed many high end race cars with turbos tend to not run a BOV and recently this has started to become a more common thing with drift cars in order to improve throttle response and reduce lag. Then today I stumbled across this article, which I must say was a pretty interesting read. Thus I feel I shall share with you all.
http://www.motoiq.com/MagazineArticl...accusumps.aspx
Opinions?
Old 08/21/2013, 01:27 PM   #2
ConHuevos!
MEXICAN
ConHuevos!'s Avatar
ConHuevos! is offline
Default Re: BOV are just a flashy noise?
hmmmm it is interesting. Would I run a turbo car without a bov, no. I would loosely relate it to using a pcv valve. i'm pretty sure it will not hurt your motor in the short term to not have one but in the long run, it will influence something to fail.
anyone on here willing to try running with no bov?
Sri Sri Ravi Shankar
Old 08/21/2013, 08:49 PM   #3
Just had my turbo freshened up. Not willing to try it, even with full throttle shifting.
Old 08/22/2013, 09:41 AM   #4
I'm very curious about this, especially on a lower boost level setup with a ball bearing turbo.
Old 08/22/2013, 05:32 PM   #5
Don't know if you remember this mike, but it can't be any worst then when Brian welded the wastegate shut on Josh Sorokas car back in the day when hey did the budget build for the SOHC....lol ha ha
I just remember parts off the block being deposited all over army post....lol.
But yeah the article sounds very intriguing........makes you wonder if it is possible to accomplish without sacrificing your money....which is what it comes down to in the end. It would be something to try if you can find everything you need for dirt cheap (like under 500 cheap) then test on a car you aren't attached to.
Old 08/28/2013, 09:21 AM   #6
I think I'm going to give this a go and just pray the whole time. I shall get back to this subject after I've gone without a BOV for a while. If the turbo ends up taking a dump on me shortly after I'll post those results up as well.
Old 09/17/2013, 07:14 PM   #7
Mienke
Mienke's Avatar
Mienke is offline
http://www.driftworks.com/forum/tech...v-rb20det.html
these guys say they don't use bovs.
91 teggy- soon to be rebuilt
91 civic hatch- daily driver/ used for my delivery job
Old 09/17/2013, 07:22 PM   #8
Mienke
Mienke's Avatar
Mienke is offline
this has me curious though
Old 09/18/2013, 05:01 PM   #9
Since I said I was going to try it I've been running no BOV and everything has been perfectly fine on 15lb's with a stock turbo. I've also put a good amount of abuse on it as well. I think it's been the best decision I've made so far. The improvements of removing it have been far better then I expected.
Increase in throttle response after being off throttle, car doesn't wanna spit and back fire anymore after the bov dumps air, it doesn't die after doing a top of rpm to clutch in, and I've also come to the belief that my old BOV must have been leaking because there's a significant increase in how quickly I build boost now.
So far so good and after doing some thinking about the subject I don't see how it could possibly damage your turbo by not running one. Off throttle you're not building exhaust pressure to build boost so it's not like closing the throttle is going to suddenly cause a crazy build up in pressure, plus with the whole "surge" thing and the turbo spinning backwards, what does spinning backwards hurt? Also you have the argument of unbalanced load of pressure on the shaft, again this one after some thought has turned the other way in my opinion. Pressure on both sides would have more stress and off balance twisting force then anything so there's no way there's some sudden amount of stress the shaft would see that it couldn't handle.
So now I'm sold on the no BOV idea. The more I think about it the more running a BOV starts to sound stupid to me. There's no actual proof I've been able to find that supports running a BOV will in turn save the life of your turbo.
Old 09/19/2013, 05:04 PM   #10
Mienke
Mienke's Avatar
Mienke is offline
good to know. this really interests me though, down the road a bit you should post how its doing so we can see long term effects. be cool to know if its still holding up solid or people were right and it does wear the turbo faster.
Old 09/19/2013, 10:25 PM   #11
What car and set up are you actually running with no bov on?
Old 09/20/2013, 08:23 AM   #12
Skyline motor (RB20DET) in an S14 240sx
