Old 03/22/2011, 01:05 PM   #1
datbeatz88
datbeatz88's Avatar
datbeatz88 is offline
Default clutch has no pressure
when i press on the clutch it goes straight to the floor without any pressure. and it will grind trying to put it in gear, low an high rpms. it jus started happening. i need help tryna figure this out. its my DD.
Originally Posted by zachv365 View Post
x2, Everytime I read something that dude says, my IQ decreases by 10.
Old 03/22/2011, 02:47 PM   #2
dsmer06
dsmer06's Avatar
dsmer06 is offline
Default Re: clutch has no pressure
Check the clutch fluid, if it's low pull back the rubber boot on the slave and check for fluid, if there isn't any check the drivers side floor/firewall for fluid to tell if it's the master. If those are all good push the clutch fork in to tell if there is a problem with the clutch itself.
1992 Galant VR4
2005 92x Aero
2000 2.5 Rs
Old 03/22/2011, 02:51 PM   #3
check fluid level on reservoir and if its full have someone get in car and press clutch in. During that time see if you can see the slave cylinder move in front of transmission. Could be your issue since it may not be engaging, thus the reason why gears are grinding.
If all checks out on those two things then we can move on to something else that might be the issue.
Old 03/22/2011, 02:53 PM   #4
Ha ha ha, Kevin you beat me to it.....we sounded alike on this!!!
Old 03/22/2011, 10:26 PM   #5
Keitsu
Keitsu's Avatar
Keitsu is offline
clutch master cylinder.
- Keitsu
http://jkeitsu.com
Old 03/24/2011, 03:51 AM   #6
TMF motorsports
TMF motorsports's Avatar
TMF motorsports is offline
My 1.5 cents worth of advise is the slave cylinder for the clutch also is notorious for going out and not giving any pedal pressure. it leaks out side the car onto the ground so may not be as noticeable until it completely fails. Make sure you bleed it well, if their is air in the line it will not compress well. Let me know if you need help.
Lotsa Mitsubishi's
http://www.TMFmotorsports.com
