Old 06/16/2011, 03:49 PM   #1
kornfedb20
kornfedb20's Avatar
kornfedb20 is offline
Default 95 gsx no power short?
my buddy has a 95 eclipse gsx one day he was driving and it just died and there was power like the lights all worked but it wont start he thinks there is a bad connection somewhere what you guys think? where would be a good place to check.
Old 06/16/2011, 04:22 PM   #2
Default Re: 95 gsx no power short?
check to see if he is getting power to the starter. if he is, check all fuses. if fuses are good, check grounds to make sure they are properly grounded. all of this can be done with a $2 tester from walmart, the one with the light in it. when checking for power, attach to a ground, and vice-versa, and if it doesnt light up, most likely thats your problem.
