Old 06/23/2011, 09:22 PM   #1
eclipse chad
eclipse chad's Avatar
eclipse chad is offline
Wrench clutch probs
how do you get the release bearing to release from the input shaft on a 2000 eclipse GT
Old 06/28/2011, 12:56 PM   #2
Dsmolition
Dsmolition is offline
Default Re: clutch probs
Compress the clutch pedal, its the pedal all the way on the left.
93TSI- 624 AWHP 500 AWTQ
EVO VIII RR GSR (yet to dyno)
Old 06/28/2011, 04:34 PM   #3
TRANSAXLE CAN'T BE REMOVED WITHOUT RELEASING THROW-OUT BEARING THUR ACCESS HOLE ON BOTTOM SIDE OF TRANSAXLE CASE------- SHOPKEY STATES NOTHING ABOUT THIS
BULLETIN COMES WITH CLUCH PACKAGE ABOUT REMOVAL
Old 06/28/2011, 05:59 PM   #4
Old 06/28/2011, 08:24 PM   #5
EvO-X
EvO-X is offline
Here's some instructions. Looks like since its a pull type clutch you stick a screwdriver through the inspection hole to release the throwout. Cheers!
http://freepdfhosting.com/c90aaf524d.pdf
