Old 03/03/2010, 09:59 AM   #1
jdmeg6 ya digg
jdmeg6 ya digg's Avatar
jdmeg6 ya digg is offline
Default problem please help
ok i bought a teg and it ran fine till i took it home it started to make a weird noise when i wasnt gasing but it sounded fine when i accelerated. then the noise just went away and it sounded fine(i was in 5th gear this whole time on the interstate) but when i get off y exit i go to downshift and it wont go into gear at all the only way i could get it in gear is if i turned my car of and started it in the gear so i get home and turn on the car this morning and it is slightly easier to get int gear but not like it should and it sounds funny when its in gear kinda like the sound of when you almost put your car in gear without stepping on the clutch
my setup is a ls with gsr tranny pleze help
JDM HONDA all the way
TOYOTA SUCKS BIG ONES
Old 03/03/2010, 11:24 AM   #2
remix Rick
remix Rick's Avatar
remix Rick is offline
Default Re: problem please help
its a slave cylender Thread closed...
94 Dodge dakota
96 Civic ls Swapped
Previously owned
84 cilica supra
94 4 door civic
89 bmw
89 crx si
91 crx si
Old 03/03/2010, 11:57 AM   #3
nate2k5
Human Bean
nate2k5's Avatar
nate2k5 is offline
it's definitely part of your clutch hydraulic system. do the following:
1. check the clutch master cylinder to make sure its not leaking
2. check clutch fluid level
3. check the clutch slave cylinder for correct operation or damage
1999 Ford Expedition
1989 Volvo 245
1977 Volvo 244
1978 Cobalt 19' BR
Old 03/04/2010, 10:36 PM   #4
jdmeg6 ya digg
also when i start the car in gear it drives without me using the clutch would any of these things damage or make my engine/car sound shitty when i rev it up bcause it does
thanks for the input guys
Old 03/05/2010, 07:38 PM   #5
jdmeg6 ya digg
can anything bad happen to the engine if it runs with no crank pully, other than the alternator not working
Old 03/05/2010, 07:40 PM   #6
jdmeg6 ya digg
oh yeah would any of these problems above affect how my engine runs
Old 03/12/2010, 09:20 PM   #7
I seriously hope you are joking
Old 03/12/2010, 10:33 PM   #8
nate2k5
Human Bean
nate2k5's Avatar
nate2k5 is offline
goodbye valves
1989 Volvo 245
1977 Volvo 244
1978 Cobalt 19' BR
