Old 04/23/2010, 11:54 AM   #1
krayzie
krayzie's Avatar
krayzie is offline
Default no power to deck
i nmy 91 accord it came with no deck so i ended up buying one i wired everything up plugged it in and no power. checked all fuses. tryed in my friends accord and it powered on. i did notice that the cars wire harness the black ground wire is cut and just hanging off conected to nothing. could that be the problem?
Old 04/23/2010, 12:12 PM   #2
ilovekswaps
ilovekswaps is offline
Default Re: no power to deck
No ground could very well be your problem
Old 04/23/2010, 12:15 PM   #3
krayzie
krayzie's Avatar
krayzie is offline
how would i go about hooking that up. from the wire harness inside the car the black cord is only extending 1-2 inches out of the harness. could i just electrical tape it to a piece of metal?
Old 04/23/2010, 12:31 PM   #4
ilovekswaps
Yeah that would work
Old 04/23/2010, 07:03 PM   #5
Just get a self tapping screw and don't do the electrical tape. You want a good solid ground and not something that can come loose first time the car gets super hot from the sun.
Old 04/24/2010, 07:13 PM   #6
arsalan500
arsalan500's Avatar
arsalan500 is offline
if that doesn't fix it...
You could take a wire from your Ac..
I had a problem with my posotive wire.. and it wasn't getting any signal.. so I stole the AC wire and turned into two... and one went to the stereo and the other to the AC
Old 04/26/2010, 07:18 AM   #7
krayzie
krayzie's Avatar
krayzie is offline
what does it mean when you take off the face plate and the deck still wont turn on but the lights flash where your cd would usually go in under the face plate
-- sorry if that does not make sense
Old 04/26/2010, 11:32 AM   #8
If the face plate Is off and you see a blinking red light it is just that, a light. It was put in by the manufacturer so it would simulate the light on an alarm system and deter thieves from trying to break In. To me it also serves as an indicator that there is power to the unit....although sometimes there is a small reserve battery that could be running it.
.....then again I could be completely wrong since I a not an audio guru....LOL somebody correct me if I'm wrong, misinformed, or this may not even be the right light we are talking about!! Ha ha
