Old 02/05/2012, 01:59 AM   #101
mycarslow
mycarslow is offline
Default Re: my prelude
What's done to your tranns to hold up to the big hit. Of spray? ... I'm just doing more fuel setup on my car and getting ready to retune it but I'm worried about my trans. Its at 404 tq now
Built h22 62mm turbo e85
Old 02/05/2012, 09:21 AM   #102
goldluderay
goldluderay is offline
trans is all stock.....i do preload on every lauch too save axle's...and when im on the shot i really dont shift very fast...im hopeing too be going a certain route with trans set-up later on after i get an idea of how the car tracks down the track.....my trans is fresh it was one of those 30k hmotorsonline deals
Old 02/05/2012, 12:56 PM   #103
mycarslow
Well that gives me some hope for mine lol.... I should be at about the 600hp mark with mine but mines a heavy ass pig maybe ill pull out the rear panles cut up a lot of shit and reinstall the and mayb the tar off the floor
Old 02/05/2012, 02:34 PM   #104
ialuder
ialuder's Avatar
ialuder is offline
my turbo lude has a pretty much a stock trans in it. the crappy phantom grib lsd...and a 4 puck clutch. stock axles.
Old 02/06/2012, 09:17 AM   #105
goldluderay
you start getting over the 350tq mark.... thats when trans games can happen...the heavier you are the worse it is the hard you shift the worse it is
Old 02/06/2012, 12:31 PM   #106
ialuder
ialuder's Avatar
ialuder is offline
true, im pretty heavy and shifts are not smooth when spooling that much psi. so my trans has done well for the amount of abuse it has taken.
Old 03/07/2012, 09:14 PM   #107
have you dynoed this bad boy yet?
Also i totally belive that if you could get this sucker to 2100lbs range.
One of my buddies pulled out all the wiring out of EF hb and only kept the wires needed for ingition, head lights, cluster, sensors & tail lights and we weighed the box of wring...
fucker was 45lbs of wiring
that's from a small ef hb dx. Now if you have a loaded prelude with pw, pl, sunroon all that crap you can easily easily gun 500lbs with out even having to do take out any cutting tools. lol
2800 to 2300 = easy
2300 to 2100, those last 200lbs is where you have to start cutting away carefully.
Old 03/08/2012, 02:06 PM   #108
goldluderay
2800 to 2300 = easy
totally doable...
i did dyno the car but had issue's...a valve guide siezed causing exhaust valve contact on the number two piston top....so im goona need a head freshen up job and one new piston...never had any issue with this head prior too this...before we statrted too notice the issue the car was making around 200tq un corrected but horsepower was only 230whp...im sure it was because that cyclinder was causing issues
Old 03/08/2012, 06:10 PM   #109
Originally Posted by goldluderay View Post
totally doable...
so the exhaust valve guide sized with the stem of the valve?
so you dropped a valve or no?
Old 03/08/2012, 06:49 PM   #110
goldluderay
yes excatally the stem sized to guide...and no the valve is still intack but its bent and chewed up quite a bit
Old 03/14/2012, 11:21 AM   #111
ialuder
ialuder's Avatar
ialuder is offline
what valves are you using?
Old 05/25/2012, 10:44 AM   #112
goldluderay
im using oem valves at this point on the old head i was on skunk 2 valves....
new pistons layout
new alainz ported head
