Old 07/17/2010, 01:37 PM   #1
tedo2007
tedo2007 is offline
Default Sub wiring
I have a 2 channel amp thats rated at 550 watts rms per channel at 2ohms...
then i have a dvc sub thats 2 ohms per side
running the 2 channel amp 1 channel to one side of sub, and other channel to the other side, will run the setup at 2 ohms to get the most power out of the amp correct?
Old 07/17/2010, 05:10 PM   #2
jdmb18hatch
Retired
jdmb18hatch's Avatar
jdmb18hatch is offline
Default Re: Sub wiring
here ya go, check this diagram out.
http://www.soundkraft.com/Subwoofer_Wiring.htm
edit: just re read your post, dont run one channel of the amp to one voice coil of the sub...
Old 07/17/2010, 05:25 PM   #3
tedo2007
tedo2007 is offline
can i ask why? i dont see a problem with it if they getting the same signal from the headunit, i used a splitter so its the same for left and right....
Old 07/17/2010, 05:54 PM   #4
tedo2007
tedo2007 is offline
subs a 15 inch brahma amd the amps a rockford 1000a2
Old 07/17/2010, 06:10 PM   #5
jdmb18hatch
Retired
well, you can blow your sub alot easier that way. lets say a spike or drop occurs in one channel of your amp..that can cause damagae to that individual voice coil. if its just a single sub i would just wire it to 4 ohm and bridge your amp..thats just my .02
Old 07/17/2010, 06:30 PM   #6
tedo2007
tedo2007 is offline
read that this amp isnt bridgeable....itll go 2 low in ohms, not sure tho...thanks for the help tho!
Old 07/17/2010, 06:36 PM   #7
jdmb18hatch
Retired
2 channel amp is bridgeable
Old 07/18/2010, 01:23 AM   #8
tedo2007
tedo2007 is offline
just because its bridgeable doesnt mean its stable when its bridged, this amp so happens to not be stable when bridged....
Old 07/19/2010, 07:15 PM   #9
jdmb18hatch
Retired
is this the RF power 1000a2??
Old 07/19/2010, 11:45 PM   #10
tedo2007
tedo2007 is offline
yes sir
Old 07/24/2010, 12:17 PM   #11
95integ-DC
95integ-DC's Avatar
95integ-DC is offline
Heres a website i like to go to that helps me out. Goodluck
www.the12volt.com
GO SAN DIEGO MOTHA F*#@ING CHARGERS!!!
Old 06/14/2011, 07:44 PM   #12
BootLip
BootLip is offline
Go to The12volt.com they have a tool to show you how to wire it up.
Old 08/26/2011, 02:34 PM   #13
Avaitors
Avaitors's Avatar
Avaitors is offline
i agree with dude above just casue it is bridgeable doesnt make it the best thing to do. if you only have one coil of the sub maintaing power that it will burn that coil up FAST. speaking from personal experience if you got two coils hook um both up
Old 02/06/2012, 09:01 PM   #14
LilKinz17
LilKinz17's Avatar
LilKinz17 is offline
for the 12volt.com
LILKINZ17
