Old 08/22/2010, 12:02 PM   #1
(dk2) devvvin
(dk2) devvvin is offline
Default Valve Gapping
I need to gap my valves on my 1990 civic hatch si, it has a d16a motor swapped into it so now the gapping is off and im shifting way too fast. ANYONE HELP, text 5076965344, looking for someone to do. I LIVE IN WEST DSM
Old 08/23/2010, 12:33 AM   #2
Default Re: Valve Gapping
get a REPAIR manual, or look the specs up google usually you do cyl 1 at tdc then 180 counter clock crank and do cyl 3 then 180 counter clock crank and do cyl4 then 180 counter clock crank and do cyl 2 last, I'd def recommend someone doing it for you if you dont feel capable,
Old 08/23/2010, 07:14 AM   #3
we can do that for you, if like ososlo says your comfortable doing it yourself. Takes about an hour ($70) and you might need a new valve cover gasket.
Old 08/23/2010, 07:58 AM   #4
bitchasscracker
bitchasscracker's Avatar
bitchasscracker is offline
turbos are like dicks...... the bigger the better
Old 08/23/2010, 12:56 PM   #5
(dk2) devvvin
Yeah i would definitely rather have someone do it for me, i do have cash and all that for it.
Old 08/25/2010, 04:56 PM   #6
just give me a call at wrenches auto to set up an appointment. 280-3485
Old 08/29/2010, 10:41 PM   #7
one-cam
one-cam is offline
Pretty easy to do if you know how to do it.. http://www.google.com/url?sa=t&sourc...d0agkcRUKjpsDw Thats how you do it if you want to do it.. To clear it up so you understand when the cam gear mark says UP is at the top you adjust the cylinder 1 all 4 valves then the intake valves on #2, and the exhaust valves on #3. Then turn the engine 360*as in crank pully bolt CCW then adjust all of cylinder 4 and the intake valves on 3 and the exhaust vaves on 2.. They will be loose and not tensioned up when you go to adjust so if it doesnt move up or down dont adjust that one.. This should help for specs its all on the net and the manuals.. Or have a pro do it.. There is a trick to getting the right clearance..
D16T 89 civic si 405whp 332wtq Jordan@MAP FTW!!!!
Old 09/13/2010, 02:23 PM   #8
SupaDave
A Better Version
SupaDave's Avatar
SupaDave is offline
Easier said than done. I've watched it performed and I would recommend not trying it if you don't have the proper tools and someone to guide ya. $70 sounds like a fair price.
Originally Posted by thatfastteg View Post
Dear Hater.... Watch me.
