Old 02/01/2011, 12:03 PM   #1
iMaTThew515
iMaTThew515's Avatar
iMaTThew515 is offline
Default subwoofer cutting off?
im not sure if i need a "better" battery or what but whenever i let off the gas and just cruise the sub starts cutting on and off, but whenever i have my foot on the gas it beats just fine...suggestions? ihave a capacitor sitting in my room, im not sure if that would help???? alternators good and the batterys not even a year old...
Old 02/01/2011, 12:28 PM   #2
dalawoi
toaster box
dalawoi's Avatar
dalawoi is offline
Default Re: subwoofer cutting off?
i would throw on the cap and throw in new fuses? also how old is your wiring? size of amp? power of sub? winter isnt nice to subs as with most electronics its very likely your amp might be going out.. happened to me last winter
2012 kia soul
1993 mirage ;)
Old 02/01/2011, 01:25 PM   #3
iMaTThew515
well i just got it off a friend its a Dual brand sub, and the wiring just came straight out of another car i looked it up and the rms is like 150 running off a 200w vr3 amp
Old 02/01/2011, 02:44 PM   #4
dalawoi
toaster box
dalawoi's Avatar
dalawoi is offline
well check the wires could be a bad ground or a speaker wire slipping
2012 kia soul
1993 mirage ;)
Old 02/01/2011, 03:34 PM   #5
iMaTThew515
just seem like the sub isnt getting enough power, prolly gonna upgrade on the battery if the cap doesnt help
Old 02/01/2011, 03:42 PM   #6
dalawoi
toaster box
dalawoi's Avatar
dalawoi is offline
ive ran 2 type r's on a stock battery no problem... my guess is something is blown.. name brand is the way to go!
2012 kia soul
1993 mirage ;)
Old 02/01/2011, 03:55 PM   #7
iMaTThew515
lol no shiet, i got it for free sooooooo....yea haha
Old 02/01/2011, 03:57 PM   #8
dalawoi
toaster box
dalawoi's Avatar
dalawoi is offline
ahhh now i see the situation well if it helps I have a 10 inch alpine type e in a kicker bazooka style box ill let go for 30 subs a month old only been installed for a week and i dont use it
2012 kia soul
1993 mirage ;)
Old 02/02/2011, 12:49 PM   #9
mr2boostin
mr2boostin is offline
run your rc wires and power wire down diff sides of your car ... try that it makes a difference
Old 02/03/2011, 09:56 PM   #10
alexbuck205
alexbuck205's Avatar
alexbuck205 is offline
first check your ground make sure its tight and paint is sanded off. do you know if you amp is going into protect or if its shutting off? to test your battery just use a muli-meter or DMM and test your battery while the car is off should be somewhere around 12volts and also test when car is running should be somewhere around 14v if its all good i would say your amp is bad.. easy to test just hook it up in someone else car.
05 CBR 1000RR REPSOL
07 Acura TL-S
Old 02/05/2011, 10:45 AM   #11
iMaTThew515
yea did it, ive always been told to due that too avoid static noise
Old 02/05/2011, 10:47 AM   #12
iMaTThew515
fixed thanks man loose ground now i just need to stop in and pick up a box
Old 02/05/2011, 11:50 PM   #13
whitsingleslamer
whitsingleslamer is offline
Dude i told u a week ago when u called me and askd wat would cause this and i told u its prolly grounding out check ur grounds
1998 White civic ls swapped sold
1997 ford f150 current
1998 gsr integra current
Old 02/12/2011, 02:41 AM   #14
iMaTThew515
yea i checked it when you told me HIT ME UP SOMETIME!
Old 06/14/2011, 04:17 PM   #15
BootLip
BootLip is offline
Dual is garbage! Is the amp going into protect mode or turning off? or is it just the sub that quits moving?
