Old 02/27/2011, 02:01 PM   #1
HANDA
HANDA's Avatar
HANDA is offline
Default Honda throttle body (TB) size chart
Taken from: http://hondaswap.com/reference-mater...e-chart-29095/
Honda Throttle Body Sizing Chart
Inside Diameters (in mm)
* d15b7 - 56
* d16a6 - 55
* d16y7 - 56
* d16y8 - 56
* d16z6 - 56
* ZC - 55
* d16a1 - 55
* d16a8 - 55
* b18c1 - 60
* b18c5 - 62
* b18a - 58
* b18b - 60
* b16a SiR - 58
* b16a Sir2 - 60
* b16a2 - 60
* b16a3 - 60
* b20b - 60
* b20z - 60
* h22a - 60
* h23a - 60
* f20c - 62
* f22 - 60
* f23 - 60
FAQ:
What are the differences between OBD0, OBDI, OBDII B16 TBs?
1st gen b16 (obdo) is a 58mm size with external map sensor
2nd gen B16 (both obdI and II) are 60mm with map sensor on top
B16B CTR throttle body 62mm, also with map sensor on top
Old 02/27/2011, 02:28 PM   #2
Alavelle12
Alavelle12's Avatar
Alavelle12 is offline
Default Re: Honda throttle body (TB) size chart
I assume the h22a tb size is the same as the h22a4 right?
1985 Toyota Corolla AE86 - Project
1994 Toyota Pickup 4x4 - Daily
1998 GSR Civic Hatch - Grey Goose - sold
2001 Prelude Base - sold
Originally Posted by Cyberwaste View Post
you will never become the pokemon master with that attitude
Old 02/27/2011, 06:39 PM   #3
HANDA
HANDA's Avatar
HANDA is offline
Yes, they should be the same size, 60mm. Only difference between H22As is the OBDs where one would have the MAP sensor mounted on the firewall instead of on the TB.
Old 04/12/2011, 03:34 PM   #4
EK/RIDER
EK/RIDER's Avatar
EK/RIDER is offline
Very helpful info im sure ill be using this chart from time to time,thanx for the leg werk!!!!
