Old 06/24/2011, 05:09 PM   #1
pirate
pirate's Avatar
pirate is offline
Default remote battery kill switch
any one know the rules? my battery is in the trunk, id imagine to go to e-ville etc, id need a remote kill.. does this have to be mounted on rear bumper? or can it be else where?
not a drag car, just a street car that wishes to partake in reindeer games at e-ville
www.facebook.com/syn-customs
Old 06/24/2011, 06:25 PM   #2
Default Re: remote battery kill switch
If the battery has been relocated from its original installed position, a remote mounted kill switch needs to be installed. It needs to be on the rear of the car, and can not be the removable key type. The way it needs to be done for Hondas (yours is a dodge I understand, but should be same), you have to intercept the charge wire from in between the alternator and the underhood fuse box. The cut-off needs to be inline with those so that when the switch is thrown, the 12v running the ECU is gone, and the car shuts down. The best style I have seen for doing this, so that you don't have to run a bunch of heavy wiring back and forth through the car is the one Tony Palo (T1 Race Development) sells. I will post a link when I get home. The work computer is not liking his website right now. I also have the 2010 or 2011 NHRA rulebook, I will take a picture and post the battery section on here for you as well.
Old 06/25/2011, 10:46 AM   #3
Here is the link for the T1 piece. http://www.t1racedevelopment.com/ind...utoff-kit.html
Old 06/27/2011, 01:13 PM   #4
pirate
pirate's Avatar
pirate is offline
nice, i run MS, so my MS controls everything, including power to alt. so looks like all i need is like u said, an interrupt via switch to kill my MS. i like the one posted, but i was looking at a push button style as well.. wonder if it still complies..
Old 06/27/2011, 02:25 PM   #5
I will look in the rulebook tonight. I forgot to do that over the weekend.
Old 06/27/2011, 03:30 PM   #6
JBAutosports
JBAutosports's Avatar
JBAutosports is offline
2010 rulebook:
MASTER CUTOFF
Mandatory when battery is relocated, or as outlined in Class Requirements.
An electrical power cutoff switch (one only) must be installed on the rearmost part of each vehicle and be easily accessible from outside the car body. This cutoff switch must be connected to the positive side of the electrical system and must stop all electrical functions including magneto ignition.
The off position must be clearly indicated with the word “OFF.” If switch is “push/pull” type, “push” must be the action for shutting off the electrical system, “pull” to turn it on. Any rods or cables used to activate the switch must be minimum 1/8-inch diameter. Plastic or keyed switches prohibited. Switches and/or controls must be located behind rear wheels on rear-engine dragsters.
Phone:
888-885-2002
SPECIAL PRICING VIA PM
www.jbautosports.com
