Old 10/07/2011, 09:51 PM   #1
turbob20vtecciv
turbob20vtecciv's Avatar
turbob20vtecciv is offline
Default popping fuse
Ok my Speedo/alternator fuse keeps popping when I accelerate quickly. It won't pop it when I'm just cruising around just when I get on it.. Any one know why?
'01 Lexus IS300, DD
'74 Datsun 260Z Work in progress
'97 Civic Coupe Turbo B20 vtec, Money pit
Old 10/07/2011, 10:35 PM   #2
Default Re: popping fuse
cause more load on the engine which increases load on the alternator. I would start by checking the alternator and the wires to the alternator and check grounds.
DO NOT OVER FUSE IT. BY THAT I MEAN PUTTING IN A HIGHER AMP FUSE. THIS CAN CAUSE WIRE TO MELT AND START A FIRE.
Old 10/08/2011, 10:04 AM   #3
turbob20vtecciv
Thanks Kelly I will start right away
'01 Lexus IS300, DD
Old 10/10/2011, 12:35 AM   #4
rex712
rex712's Avatar
rex712 is offline
i actually had the same problem and put in a bigger fuse and it never happened to me again and ran perfect
Old 10/10/2011, 12:08 PM   #5
I would say that the fuse you replaced was most likely the wrong one to begin with. But let's say it's not.
If your house has a breaker that keeps tripping, would you replace the breaker with a higher amp? I wouldn't because the wires going to that breaker could melt and cause a fire because the breaker never reached it's capacity and therefore did not trip, so the next thing to give is the wire.......viola! you have fire.
A car is the same principle.
Old 10/10/2011, 05:08 PM   #6
rex712
rex712's Avatar
rex712 is offline
i here you man and good point i was just throwing out my experience with this same problem
Old 10/11/2011, 07:26 AM   #7
There must be a short in the wires somewhere.
i had a similar problem and after carefully looking through my whole harness.... i found out that my shortage was from my o2 sensor. unplugged my o2 sensor and presto... never blew the alt fuse again.
what kind of car is it?
Old 10/11/2011, 05:18 PM   #8
turbob20vtecciv
97 civic
'01 Lexus IS300, DD
Old 10/12/2011, 10:40 AM   #9
is it a y7 or y8? they are infamous for a short in the wire harness at a certain spot.
check under your intake manifold. right above the oil filter and next to the bracket that supports your IM to the block. theres some wires there. thats where i would check first.
those ek models are infamous for a short right in that spot. i believe theres a blue or green clip back there and the wires rub so much on that bracket that it creates a shortage. thus blowing out your fuse.
is your civic throwing any check engine light codes? if it is... i bet its also throwing out p1298.
i had this problem on my y7. but if you need any help feel free to pm me
Old 10/12/2011, 07:10 PM   #10
turbob20vtecciv
its a new 00 si harness I've checked over and over i haven't found anything wrong I'm going to look into the alternator next. It just accelerates so damn fast the fuse goes oh shit lmao
'01 Lexus IS300, DD
Old 10/12/2011, 07:11 PM   #11
turbob20vtecciv
Also I plugged in the s300 no codes
'01 Lexus IS300, DD
Old 10/13/2011, 05:33 PM   #12
rex712
rex712's Avatar
rex712 is offline
thats what happened to me when i drove it without beeting on it it would drive fine but when i stepped on it would go out right away
Old 10/14/2011, 04:32 PM   #13
tu cromprendo GOOGLE ??
Old 10/15/2011, 05:34 PM   #14
mark3727
mark3727's Avatar
mark3727 is offline
My guess is there is a short also. The reason it doesnt pop until you get on it is probably because you are not flexing you engine. Meaning when you get on it your motor is moving back and possibly touching a bare wire shorting out. Just a guess but good luck! Intermittant shorts suck balls!
Old 10/17/2011, 07:42 AM   #15
turbob20vtecciv
yeah it sucks. ive been looking all over i hope i can find it
'01 Lexus IS300, DD
Old 10/17/2011, 12:01 PM   #16
I was thinking.... since you are using an s300 Hondata...
Did you delete any sensors? example... o2 sensor? knock sensor?
If you did delete some sensors... I would start looking at those sensors for the short.
correct me if I am wrong but there is probably still electric current running through the sensor even if they were deleted. Just the ecu is not trying to read them.
Thats probably why its not throwing any CEL codes.
Old 10/18/2011, 11:59 AM   #17
very good point.
oxygen sensors are a good point since the wires take so much abuse with heat and being exposed to road debris.
does the S300 have any issues with popping fuses? I thought I heard something in passing about that. Like ososlow said, it might be worth a google.
Old 10/18/2011, 09:09 PM   #18
turbob20vtecciv
Found it. When i put in the o2 wideband i ran into a wiring mess the previous owner had i thought i had taken care of it but i was wrong. They had cut the original o2 sensor plug off and tried wiring it with speaker wire, but i got all of it taken out this time lots of digging. Thanks guys.
'01 Lexus IS300, DD
Old 10/19/2011, 07:56 AM   #19
Nice. I had a feeling it was the o2 sensor.
Old 10/28/2011, 12:00 PM   #20
Avaitors
Avaitors's Avatar
Avaitors is offline
i know that this problem was fixed but i was wondering if this would be a possilbity as a casue for the same issue my friends accord is doing the same thing but the guy at the auto store is telling him that it is the tps sensor that is over powering the fuse
Old 10/28/2011, 12:21 PM   #21
does he have a tps code? if the engine light is on, need to find out the codes. if he's got an oxygen sensor code I would look at the wiring for those. you can also look at the tps wiring.
I'd start with codes.
Old 10/28/2011, 04:05 PM   #22
Avaitors
Avaitors's Avatar
Avaitors is offline
Originally Posted by deadmoans View Post
does he have a tps code? if the engine light is on, need to find out the codes. if he's got an oxygen sensor code I would look at the wiring for those. you can also look at the tps wiring. I'd start with codes.
yeah it is pulling codes but for some reason they arent clearing even when the computer is reset so its hard to tell what codes are old and what it is actually messed up but i will tell him to check the sensor out
