Old 11/12/2011, 02:23 AM   #1
Default Group Discount Street Tunning by Consummate Tuning !
Call or PM me for questions
See vouch thread on honda-tech.com
http://www.hondamarketplace.com/showthread.php?t=677742
651-226-7157
What:
Looking to see if there is any interest in IA guys getting their cars street tuned.
This would a huge discount rate before snow fall.
Looking to get min of 5-8 cars street tuned.
Tuner:
Jordan Schreyer
Over 600 cars tuned by Jordan over the past 10yrs
http://www.jordantuned.com/
http://www.youtube.com/user/maperfor.../6/HE3cx2u4ics
http://www.maperformance.com/help.php?section=about
http://www.mnsportcompacts.net/forum...-STOCK-ECU-EVO
He's been tuning cars for over 8 yrs and has tuned nearly every type of car you can think of.
He started out back in 03 by offering street tuning services "Consummate Tuning".
By definition - Consummate:
* to bring to a state of perfection; fulfill
* complete or perfect; supremely skilled; superb
* being of the highest or most extreme degree
Shop in MN began to contact him for dyno tuing service on highly modified cars & high-end sports cars. MAP decided to hire Jordan just because it would be more cost effective to hire him full time.
All the local car clubs know Jordan's tuning ability from the mopar guys, nissian crews, honda community, toyota fans, every evo/dsm & subaru & GM, ford guys. In addition, he been requested to several shops across the US & tune several times internationally in Cuba, South America & Europe.
When:
This is a limited run and must be done before snow fall.
Saturday and Sunday
Date is TBD
Where:
Location will more likely be in major city of IA.
tuning will be on street, highway (tuning partial throttle ect) and the only major WOT will more than likely be on back roads.
Services:
Any type of cars which has stand alone system.
Some cars may not require their own system and jordan will have the software to tune from stock ecu.
crome, hondata, neptune, kpro ect will work fine.
For crome make sure you have the 4pin port for data-logging
What will be provide is copy of inital maps, then final tuned map.
fuel maps can be saved if you have the software on a USB drive or extra chips can be burned.
Car will be tune for better MPG, throttle response, power, smoother powerband (vtec crossover), proper ignition timing ect. Before coming down you would talk with jordan on your setup.... mild or while and he can tell chances are he's tune a car almost like yours and also tell you what to expect.
Datalogging is free.
YOU DRIVE while Jordan tunes.
Jordan will provide instructions on how he wants you to drive each run.
Jordan will spend some time to show you how to read maps & understand what to look for when other tune your car in the future.
If a large enough group is present he can go over some FAQ, general info that most people don't know about tuning except for tuners.
Jordan always told me that if a car has no mechanical issues (CEL, boost leaks, bad sensors ect) NA should take less than 45mins to tune & boosted/FI applications less than 2hrs. If they take longer than that they are wasting your time or don't know what they are doing. MOST of the time when he tunes cars for 3-4hrs it's because cars come the dyno with issues not yet resolved.
He's tune cars in as little as 30mins (fresh rebuild, +600whp) from base map to inital break in tune. It's all about experiance & Jordan has plenty which allows him to quickly navigate around the system, quickly analyze the data and change variables to make any car perform safely & at it's best.
One of the best things about street tuning is that real data is captured in terms of load base. Sure you won't see the exact number but you will feel the difference. And he'll give you a copy of your base map vs. the tune map and you can take it to any dynoshop to do some back to back dyno pulls to see the comparisons of the before & after.
Allotment of time:
5-8 cars each day Sat & Sun.
Inspection takes about 15mins
Hooking up all sensors, wiring ect takes about 20mins
Each car may take 1-3 hours.. depends.
There will be plenty of time for 1:1 questions and answers
as well as group discussion.
There will be break for lunch as a group or individuals.
You can stay and chat with other people before/after your car is tune as you wish.
Price:
Sohc non vtec NA $130
Sohc vtec and B vtec NA $150-170
FI hondas - $200 min (depending if you need a fresh tune or just touchup.... jordan can start off on fresh tables)
Kseries - depends on setup
These rates are low just so we can get more exposure and come back for more street tuning sessions in the spring/summer.
* Jordan will bring all tuning equipment needed.
* Your car only needs to be running with out any electrical issues or mechanical issues & have insurance.
* Jordan must full inspect your car before agreeing to tune.
* Waiver must be signed to street tune your car.
651-226-7157
his old car...
His car from 5 years ago (street tuned)
Has gone 10.21@142mph
Best trap of 143mph
Best 60' of 1.53
1993 Honda Civic Sedan
H22 turbo
MB Racing front end
Lexan windows
4130 Chromoly tig welded cage
4130 Chromoly wheelie bars
Custom traction bars
Bogart wheels
M&H Slicks/Skinnies
Brembo brakes
Competition Clutch Twin Disc Clutch
Aluminum scirroco radiator/fans
Liquid/air intercooler
SOHC Powerplant
Golden Eagle Sleeves
Wiseco Pistons
SI Valves
MAPerformance Ported Cylinder head
MAPerformance Turbo manifold
MAPerformance Downpipe
Momo seat
Momo steering wheel
SDS Standalone ems
Aeromotive A1000 pump
Aeromotive Fuel Filter
Aeromotive Fuel Pressure Regulator
PLX M-500 wideband
Autometer gauges
Old 11/12/2011, 02:23 AM   #2
Default Re: Group Discount Street Tunning by Consummate Tuning !
thanks guys
Old 11/13/2011, 01:43 PM   #3
Pancho
Pancho's Avatar
Pancho is offline
Can he tune on DSM links?
92 Civic Hatch SI [Sold]
92 Talon Tsi AWD[Sold]
93 Civic Hatch SI [Sold]
Old 11/13/2011, 02:05 PM   #4
yes
Old 11/13/2011, 11:59 PM   #5
mattcossel29
jackstand ballin
mattcossel29's Avatar
mattcossel29 is offline
crap, this would be awesome if I was anywhere near ready for a tune
Old 11/14/2011, 09:58 AM   #6
you can send jordan a direct email
jdmisgood@hotmail.com
or
jordan@jordantuned.com
just tell him that I sent you and that I was working out the pricing package.
Old 11/14/2011, 02:53 PM   #7
This is just a "feeler"... to see how many people are interested.
Each car pricing may be different depending depending on systems.
Thanks guys - Charlie
Old 11/14/2011, 06:12 PM   #8
mycarslow
mycarslow is offline
I would love to get in on this. The only thing I see is that snow may fall fast. Might be better off waiting for spring. Thing more people would post if jordan himself posted on here to interact with him some.
Just my .02 cents
Built h22 62mm turbo e85
Old 11/14/2011, 07:25 PM   #9
SupaDave
A Better Version
SupaDave's Avatar
SupaDave is offline
"YOU DRIVE while Jordan tunes".
Sounds safe.
Old 11/14/2011, 08:15 PM   #10
If I was not already tuned here locally, I would have Jordan tune my stuff. He knows what he is doing. And street tuning is a pretty good way of setting up a car. You are putting the car under real life loads, which a 2400lb rotating mass does not always do the best job of. My car weighs a little over 2600 with me in it, so that 2400lbs of rolling weight that is the dyno roller is not true to the real life load of mass plus air resistance.
Old 11/15/2011, 08:00 AM   #11
Sounds safe.
would you prefer he drive and you tune ?? ,
how else would YOU, do a street tune ???
Old 11/15/2011, 03:24 PM   #12
SupaDave
A Better Version
SupaDave's Avatar
SupaDave is offline
Me personally I wouldn't do a street tune but than again I don't have a honda anymore. You guys do what you have to. Jordan definitely has a good rep.
Old 11/15/2011, 03:42 PM   #13
If, you daily drive the car and race on the street as well, a street tune is where its at. like h22pwrd said, REAL LIFE. and a great way to setup a car, obviously if you dyno tuned it for multiple hours it would be better.
Old 11/15/2011, 08:59 PM   #14
EVEN if your building a drag only car, and spend several hours/days on the dyno changing variables... at the track most nice builds still datalog their runs and have their tuner on site to make adjustments as needed.
Seeing that most of our builds do see street usage, it would make sense to street tune under all types of driving conditions and not just WOT pulls... I hope you guys can look into that some more.
This isn't a thread about how cost effective, safe or performance effective it is to street tune vs dyno. Each serves their purpose but does also overlap in function.
Cheers.
Old 11/15/2011, 09:05 PM   #15
3 cars schedule this week so far... but in MN... lol
Old 11/16/2011, 12:36 AM   #16
wwbubbajoe
wwbubbajoe's Avatar
wwbubbajoe is offline
if i could only find a tandalone worth it lol
I love how someone is selling something on CL so you email them to get more info and they immediately jack the price up.
Old 11/16/2011, 08:41 PM   #17
Pancho
Pancho's Avatar
Pancho is offline
Wish I had money to get bigger injectors.. else I could get my turtle tuned
Old 11/17/2011, 12:42 AM   #18
check out updates on new site
