Old 01/02/2012, 12:49 AM   #1
iMaTThew515
iMaTThew515's Avatar
iMaTThew515 is offline
Default d16z6 low idle??????
Lately my cars been idling really low to the point where if i let of the gas the car will basically almost kill it self by low idle im talking way under 500 any suggestions??
usually after warm up its idling a little under 1k
Old 01/02/2012, 10:28 AM   #2
wilson091
wilson091 is offline
Default Re: d16z6 low idle??????
turn your idle up and see if that helps.
Old 01/02/2012, 12:02 PM   #3
P98
P98's Avatar
P98 is offline
Bring it over today sometime I will look at it for you Asian Matt
LT1 T/A
Old 01/02/2012, 02:50 PM   #4
iMaTThew515
hahaha lemme hit you up after school 2marro if i dont get it figured out today
help/solutions????? was thinking about taking off the IACV and cleaning it to see if that helps any
Old 01/03/2012, 04:12 PM   #5
crxmonster-si
crxmonster-si is offline
when i had my d-16a6 , its idle would sit at zero . hahaha i swear .
Old 01/03/2012, 10:38 PM   #6
dat192
Honey boo boo
dat192's Avatar
dat192 is offline
My ls does the same thing but only when itssuper cold out like it's been latly just let the beast warm up for 5 minutes and your gold
1 bitch 2 bitch
fat bitch skinny bitch
Old 01/04/2012, 12:13 PM   #7
Lots of ideas: vacuum leak, faulty TPS, intake manifold gasket leaking, throttle body gasket leaking, fast idle valve needs cleaning (if it has one). That's where I would start. Ohh yea, low coolant level will do that too.
Old 01/04/2012, 12:55 PM   #8
iMaTThew515
still does it when its warmed up
Old 01/04/2012, 12:56 PM   #9
iMaTThew515
Faulty TPS might be the problem, i unplugged it the other day and idle was up where it was suppose to be
Old 01/07/2012, 07:38 PM   #10
i believe you can buy those locally at like o'reily's instead of ordering an omni one online.
