Old 02/07/2012, 01:38 AM   #1
mycarslow
mycarslow is offline
Default injector flow bench ?
Who in iowa test injectors? I got 1600s to put in my car but I want to make sure there good to go before I get them on the dyno and. Find out after its to late.
So what I want to know is there anywhere in iowa that can flow test them and make sure there tip top shape?
Built h22 62mm turbo e85
Old 02/07/2012, 04:50 AM   #2
Default Re: injector flow bench ?
I don't know of anyone in Iowa, I've heard that diesel shops can test them so you might try giving a few of them a call. Other then that you might try giving RC injectors a call and see if they will test them. Last I recall they don't charge to terribly much to do it.
Old 02/07/2012, 12:10 PM   #3
I use www.witchhunter.com
They arent local but they will turn them around in a day or two.
I've never heard of anyone around here that can offer the same service.
www.roskoracing.com
Old 03/01/2012, 11:54 PM   #4
trevor34
trevor34 is offline
I built my own. Google it its really simple.
Old 03/02/2012, 10:43 PM   #5
Lee_MA61
Lee_MA61 is offline
how did that turn out? i know you were in the process the other day.
-1984 Toyota, Celica Supra P-Type Super Red (2JZ-GTE + 74mm)
-1985 Toyota, Celica Supra P-Type Super Silver (no engine...)
Old 03/03/2012, 03:45 AM   #6
trevor34
trevor34 is offline
Good for the most part. Had some leaks to fix but worked great. I didn't try calculating my flow I just wanted to make sure they were all squatting consistent.
