Old 03/16/2012, 06:39 PM   #1
95hellatukd
95hellatukd's Avatar
95hellatukd is offline
Default NEED HELP timing issues on new build
so i got everything together and let me start off by saying ive done timing plenty of times before. just need help with this one. i came to the conclusion after double checking everything else that the head or deck has been milled. idk how much cuz i didnt have it done but one of previous owners must have. please give me some help or any info. its a high compression build and high lift cams so dont really wana just guess. and cant dial in the cams cuz i bought them used and dont have the centerline info. thanks for any info.
as u can see this lines up perfect
these not so much
everything is set at 0 degrees on the aem tru time cam gears so idk how to adjust it with the head being milled or decked. thanks again for any info
Old 03/16/2012, 07:03 PM   #2
cd8h22a
cd8h22a's Avatar
cd8h22a is offline
Default Re: NEED HELP timing issues on new build
rotate the exhaust can back 1 tooth and the intake cam one tooth than put tension on it and crank the engine over by hand about 4 to 6 full turns and recheck
Old 03/16/2012, 07:11 PM   #3
That thing is nowhere near a full tooth off. It is around 3-4 degrees. I still think they can be degree'd in as long as we track the events. Pretty straightforward. Would need to lock in the high lift lobe.
Old 03/16/2012, 08:53 PM   #4
95hellatukd
yea its about 2-3 degrees on both cams. yea mike it seems like everyone ive talked to cant or dont wana degree them in without centerline number. im willing to load up the motor and bring it were ever to have someone help me out with this. just dont wana bend a valve or anything even worse by cutting corners. thanks for responces so far.
Old 03/18/2012, 12:01 PM   #5
TOTO
TOTO is offline
I just had this happen to me. I dont remember what i did to figure it out, (my shop was helping me degree it)
It had something to do with the duel valve springs being really stiff making it look like the gears were off. I dont remember how or what i did to fix it. what i kept doing was rotate the motor, tighten the tensioner pulley to where it was waaaay to tight. and then rotated it back around, then loosened it. did this in a series of patterns and then i looked at it and it was TDC. I really wonder where that HT thread i had went. Im going to try and find it.
i dont believe (dont quote me) the milled head has anything to do with timing. it will only increase the compression in the combustion chamber making the valves closer to the pistons.
1994 Bmw 325i M3 Swap Dinan Special
1997 Civic Ex B20v Turbo.
Old 03/18/2012, 03:19 PM   #6
A milled head will definitely alter the alignment of the timing. The shorter deck and head height makes the distance between the crank and the cams shorter while the belt does not change, and it forces the cam gears to be rotated to match. It usually only throws it off a few degrees depending on how much the surfaces have been milled.
Old 03/18/2012, 06:33 PM   #7
TOTO
TOTO is offline
That's something I will have to research more lol I thought with shorter deck you just tighten up the tensioner and not the timing. Learn sometime new everyday. :)
Old 03/18/2012, 08:28 PM   #8
The tensioner just takes in the slack on the back side of the timing event. The timing event is aligned going clockwise from the crank gear.
Old 03/19/2012, 05:58 AM   #9
You will need to advance the cam gears to compensate for the milled head, probably just a degree is all it will take. That will put the cams in the correct position, but unfortunately the marks on the outer part of the gear will always look slightly retarded (slightly clockwise from lined up)
You should of course degree the cams to get it 100% in the correct place though.
www.roskoracing.com
Old 03/19/2012, 06:02 AM   #10
Looking at your pictures again that actually looks like its correct assuming that the head is milled like you say and that the belt has tension on it.
A milled head doesnt help your valve clearance though. What are the specs of the motor again?
www.roskoracing.com
Old 03/19/2012, 07:27 AM   #11
95hellatukd
Gsr bottom end with gsr rods and ctr pistons. Flat face valves in a b16 head with blox hsl cams with aem cam gears. Don't know how much was milled but it has a oem 3 layer head gasket on it. And belt has tension in pics that's as close as I can get it. I want to degree in cams cuz even 5hp is a good thing especially with all motor
Old 03/19/2012, 07:32 AM   #12
95hellatukd
Haha rosko everyone keeps telling me to have u do it. Is there anyway to do it without the centerline. With doing the right way of course. Like how webb was saying
Old 03/22/2012, 07:24 PM   #13
Aaaaaahhhhh fuck just eyeball it. What's a few thousandths of an inch between friends?
Old 03/22/2012, 07:28 PM   #14
I'm pissed because I'm most likely in the same boat with my eclipse. The head's been planed so many times I had to have the machine shop measure it to make sure I could still use it. Then based on the machine shops numbers i bought a cometic head gasket something like .40 thicker than stock and then got some AEM cam gears. Sounds like fucking fun.
Old 03/23/2012, 09:39 AM   #15
95hellatukd
haha yea best friends especially when they meet.
