Old 03/24/2012, 12:35 AM   #1
bean_bean
bean_bean's Avatar
bean_bean is offline
Default could really use some help with this car
ok as u all may know i have a 86 300zx non turbo that went throw a flud a while back well me and my cuz got it running about 5 months ago we had to change out the fuel injectors and spark plugs gave it a great tune up and cleaned out the air flow system we did everything to make sure there was no water left in the motor well after we got her running we took her over to my uncles house where it sat for the last 3 to 4 months and now she wont fire up idk why she wont i have tryed everything i tryed using starter fluid and that didnt work i dont have any ideas could someone help me she turns over smooth but just wont start up any ideas anyone anything would be greatly aprecated and helpful to me and this car
turbo bitches!!!!!!!!!!!!
Old 03/24/2012, 01:02 AM   #2
akurtzer57
akurtzer57 is offline
Default Re: could really use some help with this car
Start by checking spark, fuel, compression, and in time. Might have some old rotten gas might need tank drained and new fuel filter.
Old 03/24/2012, 12:55 PM   #3
bean_bean
bean_bean's Avatar
There's no rotten gas left in it we Droped the gas tank and cleaned it all out I have spark compression and a new filter she ran just fine 3 months ago but now she won't :(
Old 03/24/2012, 01:45 PM   #4
jdmb16crx
jdmb16crx's Avatar
jdmb16crx is offline
If it is getting spark then my guess of bad coil or dizzy is out... My 76z randomly wouldn't start the day I went to sell it and it just ended up being the coil. Hope it helps
Old 03/24/2012, 06:40 PM   #5
bean_bean
bean_bean's Avatar
I'm new to the nisans so where is that at? I know I feel stupid for asking but i want to get more into this game then just the basic lol
Old 03/24/2012, 10:27 PM   #6
paintkilz
paintkilz is offline
lol your gonna have to step your game up then if you cant find the coil. you should download the FSM for your Z and become best friends with it...the coil is usually hooked up to the distributor by a plug wire...find/follow that..
1994 Jeep Grand Cherokee-No Front end. free DD though!
1990 S13. Project. needs fenders. got parts? msg me.
Old 03/25/2012, 10:38 PM   #7
bean_bean
bean_bean's Avatar
Alright I'll check that out and see what I find
Old 04/03/2012, 10:43 PM   #8
bean_bean
bean_bean's Avatar
ight well i check everything out and everything looks good i went over the other day and tryed to pop start it and all it did was bark tires didnt even sound like it would try to start any ideas?
Old 04/06/2012, 12:19 AM   #9
trevor34
trevor34 is offline
ECU might have got wet and when you drove it it got fried, have you checked your fuel pressure, and how did you check for spark? Because you need to pull each plug and put them in the spark plug wire and ground the plug and crank the motor and make sure each plug has spark, also make sure you pull your fuel pump fuse before this, or you can buy a in line spark plug tester but either way will work. GL!
Old 04/24/2012, 10:26 PM   #10
bean_bean
bean_bean's Avatar
well i feel really stupid all i did was clean the spark plugs and she fired right up the maf is still not working again so it running a lil hard but idk if that could be cuz of the air flow sencer or not any ideas?
Old 04/25/2012, 11:33 AM   #11
trevor34
trevor34 is offline
How do you know the MAF is bad? But yes if it was bad it would run like a$$
Old 04/26/2012, 10:58 AM   #12
bean_bean
bean_bean's Avatar
Cuz when I rev it up a lil bit it just sounds like a big suction of air is getting put into the intake and we took it apart before and it was all gross inside my cuz tryed his best to clean it up and it worked for a lil bit then it went out again :(
Old 04/26/2012, 05:09 PM   #13
trevor34
trevor34 is offline
I would check the voltage at warm idle and then rev it a few times and check your results with a fsm. Do you have any check engine lights? And how did he clean it?
Old 04/26/2012, 06:32 PM   #14
bean_bean
bean_bean's Avatar
Not that I know of and he got all the crosion out of it and all the rust
Old 04/26/2012, 09:13 PM   #15
cleaning a MAF with anything other than a special cleaner for MAFs/MAS will cause problems. Like say brake clean or Carbon Clean, they ruin the MAF. and don't use compressed air to dry it off.
Old 04/27/2012, 12:26 PM   #16
bean_bean
bean_bean's Avatar
I think he just scraped the stuff off with a knife and use cocking to seal it back up
Old 05/03/2012, 07:06 PM   #17
bean_bean
bean_bean's Avatar
We let it air dry and all he used was a knife idk if it worked or not but it stoped it from messing up for a lil bit and now it's doing the same thing again
Old 05/04/2012, 02:59 PM   #18
liquidus
liquidus's Avatar
liquidus is offline
Have you tried pulling the ECU codes yet? If you haven't, please do so and let us know what it says. If you don't know how, please look at this:
http://www.nissanforums.com/z31-300z...z31-codes.html
Old 05/06/2012, 10:04 PM   #19
bean_bean
bean_bean's Avatar
no not yet and any possable way u could come take a look at it cuz everyone ive asked dont know nothing about nissans lol
Old 05/07/2012, 12:14 AM   #20
liquidus
liquidus's Avatar
liquidus is offline
I'm not against the idea of looking at it for you, but see if you can't pull the codes using the instructions in the link I posted. At least give it a try, then depending on how that goes let me know and I can come take a look. I can't make any guarantees though, I'm more of a 240/skyline motor guy then a Z motor guy.
Pulling the codes is pretty easy though, the only tool you should need is a screwdriver. Try it and get back to me.
Old 05/07/2012, 04:09 PM   #21
bean_bean
bean_bean's Avatar
alright and ya im more of a skyline motor fan lol but i just wanna get it running right and save up and do a swap
Old 05/22/2012, 03:06 AM   #22
bean_bean
bean_bean's Avatar
Ok this might be a stupid qustion but when I was first told about the motor I was told it was a turbo so I bought turbo spark plugs but it's really a n/a motor could that have something to do with it running harder then what its supposed to??
Old 05/22/2012, 11:14 PM   #23
86nissanZ
86nissanZ's Avatar
86nissanZ is offline
nope.
Shiro Special #998
Old 05/23/2012, 01:20 AM   #24
JDMxTAi
JDMxTAi's Avatar
JDMxTAi is offline
I'd Say check in Injectors are actually working or the rail, even if their new you could of had faulty ones.
Maf is a biggy
Check Rocker cover O-rings to see if oil got on the new sparks
1996 Honda Civic EX Coupe - Blown & Sold
2011 Nissan Rogue SV AWD - DD
Old 05/28/2012, 12:16 PM   #25
bean_bean
bean_bean's Avatar
Would the fuel injectors wiring connection have anything to do with it also cuz I have a couPle broken ones but they do stay on but don't latch
