Old 03/28/2012, 03:10 PM   #1
HOLLYWOOD
HOLLYWOOD's Avatar
HOLLYWOOD is offline
Exclaim ECU chipping: Can any1 chip my ecu to eliminate the 2nd o2 sensor?
1998 honda civic automatic (ya ya I knw autos suck) My CAT is clean but my CEL will stay on for a couple weeks at a time (code says my CAT is dirty... stupid emissions) that tells me I need to eliminate my 2nd o2 sensor to get this CEL to permanently stay off.
Can this be done by having someone Chip my ECU?
Thanks in advanced
Bicycle
Like freedom? www.ronpaul2012.com
Old 03/28/2012, 07:32 PM   #2
wilson091
wilson091 is offline
Default Re: ECU chipping: Can any1 chip my ecu to eliminate the 2nd o2 sensor?
Pherable.net send it in for 70$ get whatever ou want on it, 2 step, higher redline, all kinds of goodies
Old 03/28/2012, 09:59 PM   #3
Sorry I didn't get back to you right away buddy......in town we have Eric from Central Imports.....give them a holler and see what they can do. You could also try fooling the second O2 sensor by adding a spacer on it. This essentially gets it away from the main flow. Problem right now is that with the cat all hollowed out all "debris", which are in the form of blow by from cylinder, will start getting caught by the secondary sensor........this then triggers the ecu and lets you know you have a "problem"....even though you know you don't. So check with Eric first to see if there is a solution via the ecu or if you can get that sensor out of harms way.....lol
Old 03/28/2012, 10:46 PM   #4
OBD2A ecu's are not able to be chipped. They run a different type of memory configuration.
Edit: Let me rephrase that, they can be chipped, but not nearly as easily as an OBD1 ECU. They require the desoldering and resoldering of an 84 pin IC. These are soldered in by a very expensive piece of equipment when the ECU's are originally manufactured. They take a great deal of patience and skill, and some expensive tools to complete the job. OBD2A to OBD1 conversion or replacement of your rear O2 sensor would be cheaper.
Old 03/28/2012, 11:10 PM   #5
Like he said. Replace the o2 is your cheapest option, and as rodney mentioned you can rock a spacer to help it.
Old 03/29/2012, 12:40 PM   #6
If you don't want to use the spacer... just get a jumper harness(obd2 to obd1) and use an obd1 ecu. Example... if its a dx.. use p06 ecu. Or just go with a p28 and chip it. That way if you are planning to do some good mods that need tuning... you will have a chipped p28 ready.
Old 03/29/2012, 02:04 PM   #7
Can he do it for an automatic though?
Old 03/30/2012, 04:47 PM   #8
Should be able to. Just have to be an auto p28? Don't quote me though lol.
Hell bring it over and I can 5 speed swap it for you
Old 05/02/2012, 11:29 PM   #9
one-cam
one-cam is offline
T
Tuning software can delete any and all sensors on your ecu..
D16T 89 civic si 405whp 332wtq Jordan@MAP FTW!!!!
