Old 03/28/2012, 03:56 PM   #1
turbodc4
turbodc4's Avatar
turbodc4 is offline
Default Need some help!??
I have a 93 S13 vert with an sr20det and well it has a t28 turbo that decided to fry itself i am in desperate need of a turbo I can use I have a megan racing tubular manifold with the t2 flange any help would be greatly appreciated thanks
VTEC-all the lag, none of the turbo.
God invented turbo lag to give V8s a chance
VTEC: Virtually Torqueless Economy Car.
MITSUBISHI -Mostly In The Shop Undergoing Big Investments, Sometimes Halfway Incomplete
Old 03/29/2012, 09:14 PM   #2
trevor34
trevor34 is offline
Default Re: Need some help!??
Might want to try the wtb section if you havent already, and zilvia will have more options for you.
Old 03/30/2012, 12:52 PM   #3
turbodc4
turbodc4's Avatar
turbodc4 is offline
Yea I have a post on the wtb section unfortunately there aren't a lot of nissan guys out here so my luck is shitty on finding a turbo that'll work however I will check out zilvia.net and see what they have.
Thanks for the help
Old 03/30/2012, 02:44 PM   #4
trevor34
trevor34 is offline
Yeah there aren't to many 240's around these parts. But gl with your search.
Old 03/31/2012, 12:32 AM   #5
akurtzer57
akurtzer57 is offline
I would avoid a t2. Why don't you just rebuild the t28?
Old 03/31/2012, 10:37 AM   #6
turbodc4
turbodc4's Avatar
turbodc4 is offline
I would rebuild that t28. However it is a ball bearing t28 and all of the research I've done says that they aren't rebuildable so it sucks cause all I need is a thrush washer/ oil seal on the turbine side I'm gonna break it down today to see if there is a way to fix it
