Old 04/02/2012, 06:00 AM   #1
type_D
type_D's Avatar
type_D is offline
Default setting TDC
wondering if i can still set TDC (crank pulley is removed) and is it ganna give me trouble when i reassemble
Old 04/02/2012, 10:46 AM   #2
Default Re: setting TDC
The timing belt drive gear has a mark on it that lines up with an arrow on the oil pump for TDC. That is how I set mechanical timing when installing a timing belt.
Old 04/02/2012, 02:18 PM   #3
type_D
type_D's Avatar
type_D is offline
so i have to reinstall pulley then set TDC...arrows on the cam gears both point left
Old 04/02/2012, 02:23 PM   #4
EGTypeR
EGTypeR's Avatar
EGTypeR is offline
heres a picture
Old 04/02/2012, 02:26 PM   #5
type_D
type_D's Avatar
type_D is offline
ok i seee thankss
Old 04/02/2012, 02:32 PM   #6
Then there are marks on both cam gears that should sit horizontal. They would be at the 90* and 270* points on the gears. The arrows on stock gears should point up. You should be able to take a straight edge and it will run across all 4 lines on the cam gears.
Old 06/18/2012, 05:23 PM   #7
Gimpster
Gimpster is offline
They don't mean much if the key's arent on the cams though ;)
Sorry I HAD to bust your balls.
Old 06/18/2012, 06:43 PM   #8
I bust my own balls every time I do timing on an engine anymore. That is still up there in my realm of WTF moments working on Honda's.
