Old 04/04/2012, 08:04 PM   #1
yamaha
yamaha's Avatar
yamaha is offline
Default 7mgte rebuild tips
Hey guys I'm gonna be starting a full rebuild on my 7mgte because it has bad hg. And bad piston rings in the last cylinder. So just wanting some tips on the rebuild.
Old 04/04/2012, 10:43 PM   #2
WideOpenRacing15
WideOpenRacing15 is offline
Default Re: 7mgte rebuild tips
Like general tips or specifically for that motor?
Old 04/05/2012, 02:02 AM   #3
kornfedb20
kornfedb20's Avatar
kornfedb20 is offline
metal headgasket and arp headstuds 7mgte best friend.
2000 integra ls b20vtec- sold
1990 eagle talon tsi awd evo 3 16g 23psi-sold
1988 toyota supra turbo-traded
1998 mitsubishi eclipse gst-sold
1989 toyota supra 1jz bw s366 12psi.-SOLD
1989 toyota supra 2jz precision 6776 ecumasters emu-current
Old 04/05/2012, 06:48 AM   #4
yamaha
yamaha's Avatar
yamaha is offline
Yea I'm going with metal and arp but just general tips things to change or do while apart.
Old 04/05/2012, 12:33 PM   #5
WideOpenRacing15
Well check all your bearings for a start. Look at the journals and make sure there are no scratches or grooves. Replace all the seals and gaskets that you take apart or that you can see leak. you can take a straight edge to the block and see if its within spec. If it were me I'd go ahead and take the block to a machine shop and have the cylinders honed and the block decked. Might as well make everything is straight while you have it apart. I can't really think of anything else besides make sure you keep EVERYTHING organized and when in doubt, replace it. You don't want to have to this again later because you tried to save a couple of bucks now. Oh you should probably get a manuel off the internet or just buy one
Old 04/05/2012, 02:00 PM   #6
yamaha
yamaha's Avatar
yamaha is offline
Ok thanks well I'm gonna get block decked and honed the head pressure tested and plainer then I'm replacing all seals and gaskets all bearings pistons and rings metal head gasket from Titan arp head bolts oil pump water pump
Old 04/05/2012, 03:05 PM   #7
tken
tken's Avatar
tken is offline
I have a tsrm ill sell. its for a pre 89 but motor wise it should all be the same. let me know if your interested
1994 honda civic cx hatch - SOLD
2000 honda civic ex - SOLD
1989 nissan 240sx - JUNKED
1988 toyota supra turbo - SOLD
2007 Yamaha YZF600R - SOLD
2004 Dodge Neon SRT-4 - DD
Old 04/05/2012, 03:32 PM   #8
yamaha
yamaha's Avatar
yamaha is offline
How much
Old 04/05/2012, 10:17 PM   #9
WideOpenRacing15
Yeah I completely left out head work. I knew I forgot something. that's just pretty basic advice for any engine rebuild. I'm not sure of anything that is 7mgte specific. Just remember keep everything organized! That is the most important part. Use sandwich baggies and label them. When you actually start to pull out the motor take some pictures of everything. Even if you think you'll remember where something goes, it can never hurt to have an extra picture. I've even seen guys use video cameras.because it was their first time. Its impossible to be over organized when your are doing and engine rebuild. If hour have any questions don't be afraid to ask someone on here. There are a couple of guys here that know their supra stuff.
Old 04/06/2012, 04:38 PM   #10
yamaha
yamaha's Avatar
yamaha is offline
I've heard to get the block decked and I've heard that its a bad idea do you know if ur supposed to do anything to the block besides hone
Old 04/06/2012, 04:54 PM   #11
tken
tken's Avatar
tken is offline
Originally Posted by yamaha View Post
How much
$50.
