Old 07/14/2012, 08:17 AM   #1
Default 2012 Civic SUSPENSION INSTALL
Alright boys andgirls today I figured I'd start my day off with a somewhat "simple" install for all you new proud owners of the loved and hated 2012 9th Gen Civic platform.
I decided to do this to showcase the ease of the new platform along with any issues that may come along when doing your own suspension on these. Our victim today will be Trung (Trung_Ej8_#579) here at the city who is the owner of a 2012 civic and wanted us to install a set of Eibach springs from an 8th Gen civic.
Now, lucky for us people are always willing to do a little research before stopping in and Trung did his homework on this setup. Before going out and purchasing this Eibach setup and slamming it in there you'll need to make sure that you obtain two key components that will make it possible for the REAR springs to fit properly. I will show you all what I'm talking about and you'll likely need to get a hold of Trung here on jdmcity to get info on where to obtain them etc. The Eibach springs you can most certainly obtain locally through JB Autosports (which will help you also if you buy from them and go through us here for your labor discount)....for more details get on our site......
So, just like any sexual encounter with a potential partner......I decided to start the civic off from the rear (sorry, early morning humor). Anyone attempting this on their own can pretty much start up in the front or whatever makes them happy. As usual make sure to support the vehicle on jackstands or any other hoisting source (is hoisting even a word?? lol sounds weird) anywho.......do the general removal of wheels, get yourself a pop or beer and get ready to lower this thing!
((((((WARNING: The following procedures can and will be dangerous if not done safely. Imports USA will not be held liable for any injuries you may encounter while performing this install. You are on your own when doing this....OR, you can contact us to get this done for you SAFELY!!!)))))
Ok, here we go.....rear with wheel on:
you'll need to start by removing the 14mm bolt pictured and ensure you have a free jack to support it while bolt is off.
next, take the other 14mm bolt off the shock I marked with the arrow below
NOW, before we move to the next step PLEASE make sure that you have a jack underneath supporting the lower arm. The reason is that the spring is still compressed between the body and LCA. So if you remove bolts without supporting it...WELL, read disclaimer up top in RED!! BE CAREFUL with this step fellas....not fun to have a lowered car that looks good with your face looking like it went through 10 rounds with Mike Tyson!
Ok, you'll need to have a little muscle for this step as it will require you to pull down on LCA and whatever is needed to get the spring out.
You'll need to make sure that you keep the lower factory rubber piece for the new springs....DO NOT remove it!! I also marked in BLUEthe rear sway bar. The reason is you'll need to keep an eye on it. It likes to slip just under the LCA and makes it impossible for you to push the LCA up or down....so make sure it stays out of your way when you begin to put things back....nothing major, just something I ran into as a small correctable issue!
Once removed here is what I spoke about in the intro. There is a rubber piece that goes on top of the rear springs that needs to be obtained from an 8th gen civic in order to fit your 9th gen (the one on the right of pic). They will be the only two items you'll need to get aside from the springs.
Once you wedge that new spring into place, jack up the LCA back into place and before putting the bolts in use some antiseize for future ease of removal!!
I'm going to add this next step WHICH IS NOT NECESSARY FOR THIS INSTALL UNLESS YOU ARE REPLACING THE SHOCKS!!!
for removing the shock here is what you do.....behind the rear seat youll find one of these.
In the trunk area, just underneath the spare tire cover you'll find one more to remove.
Once you find those two, pull back on the cover CAREFULLY and you'll see what is pictured below. To remove, just take that 14mm nut off and remove bottom bolt underneath the vehicle. This is simple as heck and should only take a few minutes to put the other shock back in ( whether it be stock, autoparts based or aftermarket performance).
KEEP IN MIND THE ABOVE STEP IS NOT NECESSARY IN THIS PARTICULAR INSTALL!!
Old 07/14/2012, 09:02 AM   #2
Default Re: 2012 Civic SUSPENSION INSTALL
So, at this point you should of remembered each step and reversed it all and are safely done with the rear.......MAKE SURE to torque everything to specs and double check all bolts and nuts are tight or laying around waiting to be installed...lol
We move on to the front suspension now
.....THIS ONE WILL REQUIRE the use of a spring compressor. If you don't have one I would suggest getting a hold of me for help!! The ones you can buy or rent at the stores are not always safe and can REALLY hurt you and your ego.
We start by removing any clips, brake lines, bolts that are attached to your shock setup. The arrows below will show what all needs to be removed. There won't be much explanation on these other than bolt/nut socket sizes etc.
remove the swaybar end link and make sure not to strip it. use an allen wrench and 14mm ratchet wrench for removal
Once you remove the above mentioned you'll have 2 17mm bolts with 19mm nuts to take off from the shock. Keep in mind the brake assembly will only be held in place by the lower balljoint so as pictured below with red arrow.....support your front LCA and pull assembly away from shock.
Once that is done we move on to the top three bolts holding the shock assembly in...steps below will help you get to the bolts easily without too many issues
once you pop the hood you'll see these little covers....remove them
Then you will see these items I marked....those need to be removed as well (which includes the bolts)
Not pictured above is a small access cover just abovethe third back nut....it is located on your wiper cowl.....helps with removing one of the nuts, the other back nut just under the wiper arms will need to be removed with a 14mm ratchet wrench........otherwise you will never get it off. As for the front one a simple socket will do. Make sure to remove the two back nuts first and the easier one LAST!!
Next steps are to be performed by someone with equipment that can help compress the springs. Feel free to stop everything at this point, gimme a call and I can get this step done for you here at the shop!!
Mark your top hat and shock with a line or guide to ensure when removing it all, that everything lines up to where it all was before.
With the spring compressed and components off (such as the 17mm nut up top etc.) All you need to use from the old setup will be pictured below.
The cool thing about the Eibach spring is that when installing it, it is not really required to compress the spring........so you can easily put it together. If you intend on bringing it to me though, I can take care of it all at once so installing it will be easier when you get home.
Once all that is done just reverse install and get it all back on and torqued to specs.
Below are the before and after shots.............Hope you enjoyed this thread and happy Wrenching!!
Old 07/14/2012, 10:47 AM   #3
Trung_Ej8_#579
Trung_Ej8_#579's Avatar
Trung_Ej8_#579 is offline
GREAT DIY WRITE UP!
Old 09/03/2012, 10:01 PM   #4
i 2nd on the removing the inside bolt for the upper front strut. i lost a brand new shiny nut , had to buy new one at honda cost of almost $4!!!! for a effing nut.
Old 09/23/2012, 10:03 PM   #5
itsmehonda
itsmehonda is offline
How were you able to take that top nut off the front shocks? Box wrenches don't reach deep enough. Do I need an impact wrench? Thanks
Old 09/24/2012, 06:32 AM   #6
You can use an impact wrench since itll be quicker or a modified wrench that can fit into it....while you hold it with an allen wrench on center (or vise grips if your shock has no allen hole). Most of the time the easiest way to going about with this install is bringing it in to my shop if you happen to live local. Takes but a few seconds to take it out (while shock is compressed) and putting the new in....plus it is safer too, you don't want that top hat shooting at your face in a fraction of a second...lol hurts pretty good!! ha ha
Old 01/02/2013, 11:07 AM   #7
remix Rick
remix Rick's Avatar
remix Rick is offline
Any one thought about using Fit Suspension on this? When i did my buddy Anthony, Looks identical to this whole set up. Even the location of the fronts . and rears.
94 Dodge dakota
96 Civic ls Swapped
Previously owned
84 cilica supra
94 4 door civic
89 bmw
89 crx si
91 crx si
Old 01/02/2013, 11:32 AM   #8
Trung_Ej8_#579
Im pretty sure no one have not tried. When i use be on the 9thgencivic forums someone did mention that they are identical but it maybe wont work lol i know the 8thgencivic suspension will work if your using springs for the rears all you need the the 8thgencivic rear top rubber isolator as for coils same for rear but for the front you will need to lose the front sway bar.
Old 11/23/2017, 07:24 AM   #9
Desy188
Desy188 is offline
It's good that there are such reviews! Thanks to them, I learn a lot of new things!
bitpim alternative
