Old 04/18/2008, 12:45 AM   #1
racin jasin
JDM legend
racin jasin's Avatar
racin jasin is offline
Default type R toni slicks
http://www.honda-tech.com/zerothread/2278188
Old 04/18/2008, 09:17 AM   #2
2point
2point's Avatar
2point is offline
Default Re: type R toni slicks
true dat. I've allways heard 22" for the lower hp lower torque cars to give the pull of an even higher FD ratio. Not tryin to dis.. .
Turbo or K powered cars are 23+ typically
I've cut a 2.1 on streets before 205/45/16 hankook RS2s at 18psi. about a 3300rpm launch and feather first and 2nd.
by using a gear calculator though, with my tires I'm like around a 4.75 FD compared to the stock 4.35FD in a RSX-S b/c they use like 215/45/17s(24.6") stock. When I use my 225/45/15s(22.9") on the track, I'm even closer to a 5.0 FD
gear ratio calculator (doesn't figure FD ratios using different tires than stock though)
http://www.fatboyraceworks.com/gears/
Old 04/22/2008, 03:12 AM   #3
god i feel so stupid compare to u im a noob but im learning :D
Old 04/23/2008, 12:49 AM   #4
racin jasin
JDM legend
http://www.honda-tech.com/zerothread/2116325
dat
