Old 08/06/2012, 11:47 PM   #1
Jle20
Jle20 is offline
Default H22a Crankshaft pulley.. help! `
Well I just bought a new crank pulley because mine fell off on the way home saturday night pulley and bolt only.
But I have the new one in its place but the bolt Honda Services gave me in Lincoln gave me was to big..
so i guess what im asking is does anyone know the size thread count and all that good stuff so i can buy the right one that will fit!? helppp! lol have to go race friday
Old 08/07/2012, 04:27 AM   #2
Default Re: H22a Crankshaft pulley.. help! `
i would suggest looking up the part number yourself. then calling honda an say you need this part and give them the part number. an but first make sure its not the same part you already have. its gonna be hard to find that size an strength.
Old 08/07/2012, 07:45 AM   #3
^^ Bobby do you have an h22 pully laying around?
Also a heads up, a stock H22 pully will not fit, you will have to modify it by cutting it, otherwise it will hit the frame rail before you can even put it on.
I might have the original pully for that motor at home. I'll check to see after work today.
Old 08/07/2012, 07:56 AM   #4
Also you might find this link helpful. It shows all the differences between the JDM H22a that you have from the USDM H22a4 that's in america.
http://www.hondaaccordforum.com/foru...a4-info-41298/
Old 08/07/2012, 09:16 AM   #5
They say its not a good idea to cut the pulley because it makes it off balanced. I would suggest a f20b crank pulley. Hmo sells them. But I do have stock h22 crank pulley. An aftermarket pulley that's smaller that I milled down to fit. It looks great. But its not balanced even when it was brand new cause it was just a aluminum piece.
Idk how much it effects the Preformance or the life of the motor. When considering people take out the balancing shafts.
Old 08/07/2012, 09:45 AM   #6
You can also get an ATI harmonic balancer.
Old 08/07/2012, 10:26 AM   #7
Yea for $478!!!! I wonder tho how much it helps in life an in Preformance.
Old 08/07/2012, 10:29 AM   #8
I've got one on the 240, they are the shizzzzz
Old 08/07/2012, 11:18 AM   #9
Also the street model comes with two pulleys but you can take one of them off. But you would have to do a work to get the bolts to work right. Its simple tho. But for 478 dollars it better do something.
Old 08/07/2012, 11:35 AM   #10
Perfect balance, that's what it does. Super precise timing marks a full 360 degrees around the balancer. Adds wheel hp due to less energy needing to turn it. What else do you need to justify the price?
Old 08/07/2012, 11:45 AM   #11
The price to me still seems out there.
Old 08/07/2012, 06:50 PM   #12
plus it eliminates vibration on the crank and that's a good thing. in fact on my eclipse it is highly recommended to run a fluiddamper pulley when you get above 350 or 400 hp.
Old 08/07/2012, 09:37 PM   #13
My pulley for my H2B had the outer ring shaved off and was rebalanced. What H2B kit do you have?
Old 08/07/2012, 10:41 PM   #14
Its my old hatch. Has the qsd kit.
Old 08/08/2012, 06:03 AM   #15
I've read a few post on honda-tech about this just now. But I don't think I'll make it over 280hp but I'm thinking since its stroke an bored. This would probably help a little on my bearings life. Am I wrong for thinking that?
They also talked about how it also helps with saving the life of your oil pump. Could someone explain?
Old 08/08/2012, 06:58 AM   #16
Its the harmonic vibrations that supposedly kill the oil pump, but I've never personally experienced that. I'm currently running an aluminum pulley also and have before in the past too.
Fluidamprs suck for an H22, they are big and stick way out. I used to run one on my Prelude (the chassis the H22 was intended for) and it ended up hitting the frame rail it stuck out so far.
I've never ran an ATI but they sound like the better route if thats what you are looking for. Go with the steel hub version, it will be much easier to get on and off and wont get as marred up by the pulley bolt.
Personally I would either do a modded stock H22 pulley (start with a new one) or pick up a Euro-R pulley.
As for crank bolts theres 16mm threads and there are 14mm threads, so you must need the 14mm version. Its not totally clear which cranks used which, so you will just have to search around. Look up OBD1 H22a1, H23a1 and F22a1 cranks and find the bolt that has a different part number than what you have and that should be it.
Also make sure that your crank key is there and not damaged or sheared off. Alot of times thats why they fall off in the first place or they also get damaged in the process.
www.roskoracing.com
Old 08/08/2012, 07:13 AM   #17
i found one for 397 at summit racing. cheapest price i have seen. i'm probably gonna pick one up now lol.
i have a f20b/ euro pulley for sale! brand new! $130!
Old 08/08/2012, 08:38 AM   #18
[/quote]
It should be M14 X 33mm but I can't remember if that's right or not. The JDM one is smaller and it's the earlier year JDM h22 so I can tell you for sure it's the smaller one.
Also if memory serves me right, I've heard of people using the pulley off the 2nd gen prelude's b20 motor and having it work on the earlier h22. Might give that a try if it's something that you're needing fixed asap.
Old 08/08/2012, 08:53 AM   #19
Yea it is 14x33 and to be a little bit more specific on the thread pitch and bolt size that's m14 x 1.5 with a length of 33mm
http://www.hondapartsdeals.com/hpa_p...onGroupID=7950
Old 08/15/2012, 12:29 AM   #20
Jle20
Jle20 is offline
I bought the oem pulley, and put it on actually and the motor is running very weird.. I think the timings off? but i have no idea as of now. me and my buddy redid the timing, and put the new belt on..
things that are happening is..
Long start up, i have to hold the key for a while.
When its on id floor it and idle at 100.
I have no idea anymore..
some of the honda kid here think i bent valves? Help please! Ice cream cruise is not far away.
Old 08/15/2012, 07:25 AM   #21
How would the timing have gotten off? Did you mess with the timing belt or the distributer? It's on a bad tune and needs re tuned like I told you. It'll take a while to start up sometimes. You don't have bent valves, I have no idea why people are saying that. If they are talking about the "sewing machine" sound that's because of the lift the cams have that are in it.
Go get it tuned and it'll run like a beauty.
Old 08/15/2012, 07:55 AM   #22
are you still running e85? or is it back to 91? without a tune an stage 2 bisimoto cams with 750cc injectors?
Old 08/15/2012, 10:57 PM   #23
Jle20
Jle20 is offline
Yeahh i changed the timing belt on it. I was suppose to head to omaha last week to get the tune. and that what i been telling them, pisses me off tho everyone keeps say i bought a lemon and it a piece.
its a thing of beauty.
e85 is gonna stay in it for sure lol not going back the take crap 91 hahah
Old 08/21/2012, 01:55 PM   #24
Well...I guess there is a chance you might have the timing off for the belt. The one cam gear was degreed so I can see how you might have accidentally been off a tooth without realizing it.
