Old 08/21/2012, 09:23 PM   #1
turboteggy
turboteggy's Avatar
turboteggy is offline
Default Suspension swap
I am going to be doing a suspension swap and any advice will be much apriciated. Im going to be swapping the susoension from my 95 teg gsr to my 97 civic ex. Thanks in advance
when the turbo spins the bullshit ends.
VTEC all day!!! well till you run out of oil.
Old 08/21/2012, 10:09 PM   #2
ej1_dohc_vtec
ej1_dohc_vtec's Avatar
ej1_dohc_vtec is offline
Default Re: Suspension swap
What do u need to know its the same suspension the only diff is the springs the.integra.ones are stronger
Old 08/21/2012, 11:06 PM   #3
turboteggy
turboteggy's Avatar
Im just wanting to know if theres anything im gonna have a problem with or just any info that will be helpful. Like I have to use the gsr axles right?
Old 08/22/2012, 02:49 PM   #4
Pancho
Pancho's Avatar
Pancho is offline
why are you wanting to transfer suspension?
what are your overall goals for this??
92 Civic Hatch SI [Sold]
92 Talon Tsi AWD[Sold]
93 Civic Hatch SI [Sold]
Old 08/22/2012, 06:23 PM   #5
turboteggy
turboteggy's Avatar
well on the front the civic is missing some studs and the gsr is not. the back has drums and i want disc. and last all the struts on the gsr have tein lowering springs.
Old 08/26/2012, 01:16 PM   #6
hflshane
hflshane's Avatar
hflshane is offline
Don't forget the 40/40 prop valve for the disc brake swap and the ebrake cables but for the most part its all the same. The info for any question you have is probably out there. Otherwise I'm doing the same thing now if you have anything specific.
Life Begins at 9000rpm
Old 08/28/2012, 09:42 PM   #7
The rear struts are different between EG/DC and EK. The EK uses a narrower bushing on their lower control arm. The lower control arm is also longer on the EK.
Old 08/31/2012, 10:10 PM   #8
93hondadelsol
93hondadelsol's Avatar
93hondadelsol is offline
And if they havent been broke lose before a torch will be your best friend!!
Old 10/03/2012, 08:26 AM   #9
Why would you need to use gsr axles? You would only need tye axles if you swapped the motor to the gsr
Old 10/04/2012, 07:00 PM   #10
hflshane
hflshane's Avatar
hflshane is offline
Did the DC chassis ever change that or was it just the civics?
Old 12/04/2012, 12:49 PM   #11
95_coupe
95_coupe is offline
dc was the same all the way through the only different integra was the itr from the gsr,ls,gs,and rs
