Old 09/06/2012, 03:09 PM   #1
95lstegra
95lstegra is offline
Default Need help wiring cd player
Hey i have a 95 ls that i bought and the guy did a hack job on the wiring harness. I bought the oem reverse harness off ebay and got it wired up. The cd player wouldnt work, i found a wire color list for the wires and it says that the red and yellow should be a 12v acc. I have no power in any key postion on this wire. Now if i put the red wire onto the white and blue factory wire with the yellow it will power on. But if it powers on in the on postion there isnt any music unless the key is in the off postion. Im completly stumped! Ive checked the fuses they have power im started to get mad ive been at it for a few hours researching and getting no where.
Old 09/27/2012, 08:30 PM   #2
yohnivilla
yohnivilla's Avatar
yohnivilla is offline
Default Re: Need help wiring cd player
Try hooking it direct to battery or to your fuel pump wire that goes all the way to the front
SOLD TOYOTA CAM 95
SOLD HONDA CIVC 94 EX
SOLD HONDA CIVIC 97 DX
SOLD ACURA GSR 97
TOTALED ACURA TL 04
SOLD MAZDA RX8 07
SOLD GSXR 600 05
SOLD HONDA CIVIC 03
SOLD PONTIAC 03
REPAIRING MY TSX 05 WITH A CL7 FRONT END
"ITS ALL ABOUT VTEC"
Old 12/19/2012, 11:55 PM   #3
canyonsnextstar
canyonsnextstar is offline
dont hook it straight the the battery unless you have a fuse in between, youll get too much power to it, make sure the remote wire is connected correctly? check all the speaker wiring you might have a couple swapped without noticing since some wires are extremely similar
Old 01/08/2013, 08:33 PM   #4
123brancamp
123brancamp is offline
the red i believe is constant 12v and yellow hook up to a 12v supply that turns on when you turn the key into the on position and black ground and then the different speaker wires
Old 11/17/2013, 07:01 PM   #5
lsvteceg45
lsvteceg45 is offline
bump
