Old 11/27/2012, 01:36 AM   #1
4DRLX
4DRLX's Avatar
4DRLX is offline
Default Strange cd player issue.
Ok. Heres what I have.
93 del sol si with a jensen flip up.
Got all the wires hooked up and before I finish and set it in the dash I test.
So heres the issues. I have 2.
1. The unit will only power on when the key is in accessory position. If I turn it one more time to the on position it shuts off. If I go straight from off to on position it remains powered off.
2. Problem 2 is that when the unit is powered on and I turn the volume up to say 29 it will reset as in reboot the cd player and play where it left off.
The first issue is completely odd to me but im thinking the 2nd issue is due to needing more power as in straight 12ga from the battery with a fuse. And a 12ga ground.
Anyways please post opinions on both issues. Tia.
Old 11/27/2012, 08:39 AM   #2
Default Re: Strange cd player issue.
Bad ground. Fix the ground wire so it's grounded out better and it should take care of your issue. Or at least the second one, not 100% on the first one.
Old 11/27/2012, 11:40 AM   #3
4DRLX
4DRLX's Avatar
4DRLX is offline
Default
Thanks nick for some reason that solved both issues but im glad its working
Old 12/11/2012, 05:19 PM   #4
wpk24rsx
wpk24rsx's Avatar
wpk24rsx is offline
Try your ignition switch i have a 90 da, assessory would turn stereo on. but once car was on stereo would not work neither would my heater it sucked it happened on black friday and i replaced ignition switch now they both work or try to jiggle key a little when car is on
JDMDC5
'flush 91 DA jdm Beast16A
im so jdm my blood is milanomy bones are champion white and my middle initial is R
Old 12/11/2012, 05:53 PM   #5
^^ since you didnt notice I figure I should point out that it was the ground and he already fixed it per his last post.
