Old 05/25/2013, 09:49 PM   #1
arsalan500
arsalan500's Avatar
arsalan500 is offline
Default sr20 issue
picked up a 02 infiniti G20, with a mint body dirt cheap. Car needed a headgasket, but the motor in too poor of shape to rebuild. (head cracked).
Found a motor from a 99, thought it would work, when installing it, noticed the intake manifold's looked differenet, then noticed the switches dont match up. So I just replaced intake mani's with the old one.
Any one ever messed with these p11's?
will I need to swap ecu's as well?
Both the motors say sr20D on them
1995 Eclipse GSX(Project Rebuilding)---------------Still Own
1995 Eclipse Gst(Good Dsm)-------------------------Still Own
1994 Honda civic, b16 swap, Blacked out-----------Still Own
1997 Nissan maxima (rebuilding)--------------------Still Own
Old 05/28/2013, 08:41 AM   #2
Default Re: sr20 issue
Just run whatever ecu you had in the car already, should be fine as long as you swapped over everything from the old head onto the new one which is sounds like you already did.
Old 05/30/2013, 10:47 PM   #3
arsalan500
arsalan500's Avatar
i swapper over everything I could, broke the knock sensor, but the plug is the same on both, so Im going to try starting it with that. just got a few vaccum lines, and it should have the first start tomo!
