Old 05/31/2013, 09:18 AM   #1
civicex_1134
civicex_1134's Avatar
civicex_1134 is offline
Default EG front suspension
So im gettin ready to swap out the front lower control arms on my 95 civic, but i know theres a certin "bolt/nut" on the most front inner part that a lot of ppl have trouble with. theres a bolt with a welded nut on the back side but the nut is enclosed in the subframe. Ive seen it where the welds on the nut will break and ur screwed.... Has anybody taken these off before? And if so how did u go about getting this nut/bolt combo off? Thanks.
Dallas
99 civic EX clover green, mini me SOHC-RIP
91 Integra GS, MR-sold
91 civic 4D-LS/Vtec, 75 shot-sold
91 Integra GS, champ white-sold
95 civic coupe, project car, turbo LS to be
Old 05/31/2013, 09:56 AM   #2
Default Re: EG front suspension
Dallas
Never heard of this being a problem nor had the problem myself. I've removed both of my lower control arms from my EG and had no issues with it at all. I'm also not sure what nut you're talking about.
Old 05/31/2013, 10:06 AM   #3
civicex_1134
Ill have to take some pictures of the bolt im talkin about...... But for example: ur standing at the front of the car, looking per say at the passenger side. from left to right u have the following: lower ball joint seat, lower strut fork bolt, then u have the bolt im talking about. it looks like just another bolt but when u look on the back side of it, its enclosed in the subframe.....
Old 05/31/2013, 10:12 AM   #4
Here I found a picture of some LCA with the brackets still on them for the rear most mount.
Could you copy this in MS paint and circle the section you're talking about then re post it on here?
Old 05/31/2013, 10:57 AM   #5
Put gear oil on those eBay bushings. Should make it jdm as f*ck!!
Because... Oil of gear
Old 05/31/2013, 11:44 AM   #6
I'm not even going to bother with repeating myself again.
Old 05/31/2013, 11:56 AM   #7
Pb!
Old 05/31/2013, 01:59 PM   #8
^^ can't. It's not jdm enough.
Old 05/31/2013, 07:11 PM   #9
Dallas, the inner pivot point is the one you are talking about, correct? Not the compliance bushing in the rear. I personally have never had an issue with it either. Rear lca's, now that is a different story. I would personally try and tighten it first, see if it moves, then try and back it out. You can also try and push downwards on the lca, and see if the bushing is frozen. If the sleeve is frozen to the bolt, it will twist in the rubber.
Old 06/01/2013, 06:20 PM   #10
civicex_1134
These are the ones im talkin about....... the "nut side" of these are enclosed in the subframe
Old 06/01/2013, 07:05 PM   #11
Yup. Those are the ones I am talking about.
Old 06/06/2013, 02:05 PM   #12
Completely forgot about those being inside the subframe. It's been a long time since I messed with my LCA. There's really no way to prevent it from breaking loose, if it happens then it happens and you'll have to take care of fixing it by either replacing the subframe or cutting into yours, welding the nut back in place, and welding the subframe shut where you cut into it.
Old 06/17/2013, 11:35 AM   #13
civicex_1134
Well, i replaced em without a hitch!!! thank god. I soaked em in PB blaster over night, then shot em again before i went after em with a impact. came right out. thx again guys
Old 06/17/2013, 02:10 PM   #14
I called it. My car knowledge is so deep. Lol
