Old 10/17/2013, 09:18 PM   #1
gooseberry09
gooseberry09 is offline
Default braided brake lines
are there any places that sell extended lengths of steel braided brake lines? like ones that would run from the front of the car to the rear under the vehicle. i bought jesses, civic and it needs new lines that go to the rear its becoming quite the project.
Old 10/18/2013, 07:38 AM   #2
Default Re: braided brake lines
Why not just make your own lines? Why run stainless steal braided all the way to the rear under the car also? Would be much less expensive, easier, and cleaner if you used hard line for the under car portion. Then in the wheel wells use braided line instead of the stock rubber hose that's used.
Either way if you want to buy it locally the only place I can think of that might have some on hand is Karls Performance.
Old 10/18/2013, 10:27 AM   #3
gooseberry09
im just seeing what i can do right now, because when im finished with those im going to have to replace the fuel lines as well. there was a plastic cover over the lines and whoever had it before jesse or I didnt take care of it so those lines are rusted out.
