Old 02/11/2014, 07:52 PM   #1
Drico
Drico's Avatar
Drico is offline
Default Brakes
I'm having problem wit my 94 integra brakes they work but when press them they loose pressure and I have to pump them so it brakes right if I don't pump them then I will crash cause they don't brake
Old 02/12/2014, 03:23 PM   #2
Default Re: Brakes
Either they were bleed poorly, you have a leak somewhere, or your master cylinder is going bad. Check your fluid level to see if it's low, check inside your car by the brake pedal to see if your master cylinder is leaking inside the cabin, and check each caliper to see if any of them are showing signs of leaking.
That's where I would start.
Old 02/12/2014, 04:19 PM   #3
Drico
Drico's Avatar
Drico is offline
Default Re: Brakes
The fluid level is good and I checked for leaking I'm gonna try to bleed them thanks for the help :
Old 02/14/2014, 02:11 PM   #4
LowNsloEJ6
1SickUA7
LowNsloEJ6's Avatar
LowNsloEJ6 is offline
Default Re: Brakes
seal in mater cylender is bad
08 TL-S
97 EJ6 D16Z6
Old 02/16/2014, 08:52 PM   #5
dat192
Honey boo boo
dat192's Avatar
dat192 is offline
Default Re: Brakes
Same problem with my old teg. Turned out to be a master cylinder. After parts and paying a guy cause I didn't wanna do it I paid 110$.
1 bitch 2 bitch
fat bitch skinny bitch
Old 02/17/2014, 03:38 PM   #6
Drico
Drico's Avatar
Drico is offline
Default Re: Brakes
Thanks a lot guys I'm gettin a new master cylinder
